Anybody have model# for 12v optima yellowtop Bat. for 2012 pip?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bulldogbob, Aug 26, 2017.
  1. bulldogbob
    bulldogbob Junior Member
    Optima site shows no match, but I've heard folks mention they've used a yellowtop battery, but they didn't mention model #
  2. MattStevenson
    MattStevenson Member
    57
    35
    US
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I believe it is the same batter as the regular Prius:
    DS46B24R
    Weight:
    26 lb
    C20 Capacity:
    38 Ah
    CCA:
    450 Amp
    Width:
    5.02 in
    Length:
    9.27 in
    Height:
    8.89 in
  4. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Can someone say with 100% certainty that the DS46B24R is the right battery for a Plug-in? When I wrote to [email protected] back in December they replied "For a 2012 Toyota Prius the Yellow Top DS46B24R is suggested." Maybe one of you guys can get a clearer answer from them.
    #4 Pluggo, Aug 26, 2017
  5. MattStevenson
    57
    35
    US
    You can put it in on the website.
  6. Pluggo
    608
    532
    Tried that and their battery finder has nothing for the plug-in. See photo...
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Perhaps @Tideland Prius knows. He gathers information from everywhere.
    Pluggo likes this.
  8. Tideland Prius
    16,128
    Not this time :(
    Perhaps @Mendel Leisk knows?
    Prodigyplace likes this.
  9. Mendel Leisk
    38,659
    I'd go with @JimN bet.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    How about @bisco He has a PiP.
  11. bisco
    49,399
    original battery. i agree with jim, no reason it would be different. since o/p is in fl, let's try @TampaPrius.com :p
  12. Prodigyplace
    11,696
    11,318
    Central Virginia
    Good call!
    Just to make sure they get the message, I nominate @jerrymildred to assist :D
  13. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Same here, I suppose. In fact, I should explore that sometime and see what's actually in there. Todd will know almost for sure.
    bisco and Prodigyplace like this.
  14. Prodigyplace
    11,696
    11,318
    Central Virginia
    You are local to Todd to I figured you could prod / bribe him for an answer. If he can put Gen 4 battery cells in an older Prius, he should have the answer to this.
  15. jerrymildred
    11,508
    14,109
    Tampa, FL
    Well, to be perfectly accurate, they were gen 3 (2015). I'll send him a text tomorrow if he doesn't show up here first. He's pretty busy and doesn't check in real often.
  16. bisco
    49,399
    can you clarify that jerry? what do you mean they were gen 3 2015? i must be missing the context.
  17. Mendel Leisk
    38,659
    bisco, jerrymildred and Raytheeagle like this.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Since we were talking about owners manual books in another thread and you provided a link to McGeorge Toyota, I thought I would merge the 2:):
    Classy and still does the job after 8 years(y).
  19. jerrymildred
    11,508
    14,109
    Tampa, FL
    Response to @Prodigyplace -- "You are local to Todd to I figured you could prod / bribe him for an answer. If he can put Gen 4 battery cells in an older Prius, he should have the answer to this." The cells in the battery I installed in my wife's '07 (Gen 2) came from a 2015 (Gen 3) that had been totaled. Todd "just" moved them from the 2015 battery case to a Gen 2 battery case and then may have balanced it, but being that new, it may not have needed it. Runs GREAT.
    And it looks like @Mendel Leisk has sniffed out the solution to the 12V battery question, so I won't bother Todd. I saw no reason for the PiP to be different, but it's better to be sure. Thanks, Mendel. Great work. I took a couple pictures of mine for reference, but I didn't go to the bother of pulling it out for a better look. I don't know if it's the original, but I think it probably is.
  20. bisco
    49,399
    gotcha, thanks. i think pp was talking about todd's experiment of using gen 4 cells in a gen 3, which was successful.
    or maybe i'm totally confused.:confused:
    jerrymildred and Prodigyplace like this.
