Anybody installed Oil catch can on Gen 2 ? any instructions would be helpful.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jay90, Oct 26, 2018.
  1. Jay90
    Jay90 New Member
    Detroit MI
    I saw this oil catch can which i want a install in my gen 2 prius. Any instructions would be helpful here. Thank You
    51,774
    is it needed on gen 2?
  3. Mendel Leisk
    41,192
    Gen 2 has Positive Crankcase Ventilation, so probably useful. For starters: remove the engine air intake paraphernalia, push the throttle blade open and look through, see if there's an oil pool below? Better: remove the throttle body, to get a better look. You should be able to leave all the coolant lines attached I think.
    If you decide to install an Oil Catch Can, in a nutshell, what you do is splice it in, in series, along the line running from the Positive Crankcase Ventilation valve and the intake manifold.
    Even though it's 3rd gen, I'd read through @danlatu 's thread:
    Oil Catch Can, Eliminate that knock! | PriusChat
    There's a couple of relevant 2nd gen Repair Manual sections attached. I would not assume all the removal they recommend is necessary for access. It may be, but take it with a grain of salt.
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    I almost wet myself laughing so hard.....
    Really?
    edthefox5 likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Haven't yet, though I've thought about it for some time :whistle:
    Unsure if mine would catch much, as I've yet to notice moisture on either end of the PCV hose. Maybe if I actually replaced the PCV instead of cleaning it there would be more blow by :confused:
    Blaze the trail for other gen2's, and please post photos with any caught fluids (y)
    m.wynn and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Probably not as necessary on the Gen2 as the PCV valve is on the top of the engine.
    But only one way to find out(y).
    edthefox5, bisco, SFO and 2 others like this.
  7. bisco
    51,774
    is this a solution without a problem?
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We’ll only speculate without data:p.
    But that’s what we do best sometimes (y).
  9. Mendel Leisk
    41,192
    Someone needs to get off their duff and try it. Maybe @05PreeUs? :p
    bisco, Raytheeagle and m.wynn like this.
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We almost got @SFO ’s at a meet up, but other work got prioritized :cool:.
    I know he’s amicable:).
    But I think results will be less impactful (y).
    bisco and Mendel Leisk like this.
  11. 05PreeUs
    1,097
    564
    MSP
    NOT A CHANCE :cautious:
    To quote others "A solution without a problem", LOL!
    bisco, padroo and Mendel Leisk like this.
  12. Mendel Leisk
    41,192
    Yeah, again: someone with a second gen, say @Jay90 (the OP), could have a look at their intake manifold, resolve this.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I can guarantee there’s a little pool of oil in the bottom of the intake because that’s normal. That’s not coming
    From the pvc but the atkisson cycle mode of the engine. It’s there when the car is new because I bought my 07 new. It’s because
    The expansion ratio of the atkisson cycle pushes charge back into the intake.
    The intake manifold is designed with a large integral plenum or surge tank to accommodate this expansion.
    #13 edthefox5, Oct 27, 2018
    SFO, bisco, m.wynn and 1 other person like this.
  14. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Agree, Ray.
    The turd gen catch can crowd feel the lower-on-the-block PCV location is a design fail. They may be on the right track, I'm undecided and still no catch can on my turd. PCV on the valve cover and I don't really see a catch can worth the time on a port injection engine.
    bisco, Raytheeagle and edthefox5 like this.
  15. Mendel Leisk
    41,192
    Prior to my (third gen) OCC install I had at least 1/8" of stuff, in the intake manifold's "sump", below the throttle body. Which begs the question: how much of the oil/gas/water vapour pulled through by the PCV valve did not settle there, instead passed through, back into the combustion chambers.
    I had a look recently, about a year post OCC install, the sump is clear. It has an oil "sheen", but that's all: no swimming pool. And yeah that seems to originate as spit-back from the intake ports: when I last had the manifold off (a second time, soon after first cleaning) I could see a drop or two of oil at the threshold of each intake port.
    In a year, and around 10K kms, I've collected about 80 cc's.
    (These are small jars btw, not gallon pickles jars, lol.)
    #15 Mendel Leisk, Oct 27, 2018
  16. Mendel Leisk
    41,192
    I was trying to sell my son on an OCC for his new Mazda CX-5 (port injected only), but he got cold feet. Maybe in a year we can check the intake manifold see what it looks like. I have one ready to go, lol.
  17. padroo
    padroo Senior Member
    2,763
    2,252
    It's getting kind of late for the Gen 2 isn't it? The average age of cars on the road is 11.6 years. If it ain't broke don't fix it.
    edthefox5 and m.wynn like this.
  18. Mendel Leisk
    41,192
    I posted a question on 4th gen forum, asking if anyone was considering an OCC. They're all too busy playing with Entune and what have you...: their "winter" will come... :ROFLMAO:
  19. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Mendel you save the crap that you found in the bottom of your intake?
    That’s pretty looney tunes.
  20. Mendel Leisk
    41,192
    OP maybe long gone, and the debate rages on. :rolleyes:
    05PreeUs likes this.
