Anybody know if there is any difference in MPG with 17x8 wheels?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Lucky Lager, Jan 15, 2014.
  1. Lucky Lager
    Lucky Lager Junior Member
    87
    17x7 vs 17x8 Anyone have experience with this? Looking at getting TSW Nurburgring wheels but they only come is 8" widths.
    Is there any real diff in 17x7 vs 17x7.5 vs 17x8's? In relation to MPG gain/loss, steering/handling etc - whatever info you have.
    Thanks for any help, I just can't decide on a wheel set :)
    49,693
    definitely a 4-6 mpg hit.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    The OP is asking about differences between different width wheels in the 17" size, not with respect to 15" stockers.
    Yes, the diameter/width is one of the major factors that influence mpg so you'll in theory get a bigger mpg hit with wider wheels. Wider tires will also increase the rolling resistance and frontal aero drag.
  4. Lucky Lager
    87
    Ok interested in the TSW's they are less than 18lbs per wheel (17x8) So I was curious if this light wheel (relative) with a stocker size LRR tire 215/45/17 would be a good trade off without a "real" hit in mpg....curious if anyone has some hard data here. Im not super concerned about the mpg just like to know and not be surprised if its more or less than I thought
  5. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Unfortunately, unsprung weight isn't a major factor in mpg but mostly affects acceleration/deceleration and other aspects of handling/ride performance. You won't be able to fully compensate for the mpg loss as a result of going wider by opting for lighter wheels. However, if you can fit 215/45/17 and good LRR tires on 17X8, the loss will be less compared to wider tires.
  6. Lucky Lager
    87
    Thanks 32K!
  7. bisco
    49,693
  8. Lucky Lager
    87
    Thanks bisco
  9. runnerstreet
    runnerstreet Junior Member
    Baltimore
    Lucky Lager,
    I'm looking at the same setup. Actually, I just pulled the trigger on a set of Niche 17x8, and plan to use the stock Toyo 215/45 tires.
    Did you end up going with this setup? If so, what are your thoughts? Did it stretch the tire too much? How is your MPG after the change over?
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    My guess is yes but minimal. Rotational mass increased and probably aerodynamics take a hit too. Using my previous cars as reference, my guess is about 1 mpg hit.... ;)
    Notice most electric performance cars, with big wheels like the i3 or Tesla, relatively speaking, they are tall and narrow tires. The little i3 has optional 20" wheels. That car was actually fun to drive. Love that torque.
  11. runnerstreet
    Baltimore
    Yeah, my research and guess tell me with the 40mm offset vs the 50mm stock offset, plus the 1" overall wider wheel, it will be poking out just a lil too much to take advantage of any aerodynamic advantage. I don't think
    I'm gonna go with the niche's after all.
    Back to the drawling board...
  12. timc1475
    timc1475 New Member
    East Peoria
    I think the affect is minimal especially for city driving, slightly more for hwy. Maybe 1 - 2 mpg tops IMO, as long as your new tire choice is also a low rolling resistant design. I have my prior new set for sale btw. Unsure how to go about that though. Any ideas feel free to drop me a message
