Anybody knows what´s the purpose of this?
Discussion in 'Gen 3 Prius Technical Discussion' started by mygel, Aug 14, 2017.
  1. mygel
    mygel Junior Member
    46
    24
    Slovakia
    anybody knows what is the purpose of two button-like pins in front bumper right behind the signal lights?
    Thanx in advance
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Can you post a picture? Mine has no pins on the bumper of any kind that I can see.
  3. douglasjre
    douglasjre Senior Member
    2,097
    701
    Null, NL
    Tow hook in trunk screws in for cable to pull car on to flatbed
  4. Tideland Prius
    16,445
    On the side of the front bumper? That look like reverse sensors?
    Those are for IPA's Pre-Support function.
    mygel likes this.
  5. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Thank you! Yes, they look like reverse sensors.
  6. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Thanks but i think you mean the square covers. Tideland has solved this, they´re intelligent parking assistent sensors.
    I forgot that i have this option, never tried it.
  7. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Huh...? o_O
  8. mygel
    mygel Junior Member
    46
    24
    Slovakia
    #8 mygel, Aug 15, 2017
  9. Tideland Prius
    16,445
    Pre-Support for Intelligent Parking Assist. Toyota found out that people were not positioning the cars properly before using IPA so the "failure" rate was high (and so was the "it's useless" and "why bother?"). Pre-Support guides the driver to position the car properly so that all the driver has to do is press "OK" on the screen without having to fix the box to change it from red (unable to park) to green (vehicle is clear of obstacles). This leads to faster/smoother operation.
    Yes and no.
    They are for the Intelligent Parking Assist and will not actually provide any guidance that you would expect of "parking sensors" (like the reverse sensors)
    i.e. they only work with IPA.
    mygel and KennyGS like this.
  10. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Yes, that makes sense. Thanks for explaining how it works, but it will take me some time to get familiar with this system, i even turn my head backward when reverse although camera is on....Customs make all things easy:)
    Tideland Prius likes this.
  11. Tideland Prius
    16,445
    You're welcome. In North America, that feature has its own chapter in the Navigation Manual :eek: (Chapter 7).
    That's still a good habit to keep. If your body allows it (I know some people have neck issues or back issues that disallow them to turn around), looking out the rear window is still the better option as the view is not distorted by a fish-eye lens and I find I can reverse faster since I can see where I'm going. I use the camera for the final bit as I approach other parked vehicles.
    mygel likes this.
  12. mygel
    mygel Junior Member
    46
    24
    Slovakia
    This lovely car came with two thick (!) books, one for the car and one for navi. For me the best and fastest option is to poke my head out of the window and look back (way back habit from the trabant years:), but as u said for the final bit is ok to use the camera, although when you park (reverse) to curb, you can go little bit more behind the red line...The curbs here (SK) are sometimes stupidly high so i scratch my front bumper several times from the bottom only but got upset with that. Gonna install a front distance sensors...
  13. Tideland Prius
    16,445
    I don't know if it was you but someone installed a FLIR camera on a Gen 3 in the front bumper. It could double as a front-end camera to view the curbs. (Like Toyota/Lexus "Wide-View Monitor" on the Land Cruiser)
  14. mygel
    mygel Junior Member
    46
    24
    Slovakia
    No it wasn´t me, but i´m afraid if i´ll be able to install something like that, i mean not the wiring job around, but make it compatible with the navi screen in order to capture front camera view like rear camera does.:unsure:but i´ll do a research about FLIR, thanks for advice..(y)
  15. Tideland Prius
    16,445
    The person that installed the FLIR had a separate monitor that he left on the dashboard. I think it came with the FLIR unit.
    mygel likes this.
  16. Mendel Leisk
    40,584
    That's infrared imagery?
  17. Tideland Prius
    16,445
    Correct.
    Although now you can use your smartphone (but plug it in since it'll be running for the duration of your drive).
    Wouldn't mind having a system like that for the winter months. Snow covered roads actually make it easier to drive at night, reflecting the street light. Rain.... not so much.
    I drove a friend's A7 several years back that had an infrared camera with pedestrian detection. It would put a yellow box around a pedestrian it detected and worked well. The only problem was that it was in the IP between the speed and tach rather than as a HUD.
