anybody use adapters for Tesla charging stations?
Discussion in 'Prime Plug-in Charging' started by AnneLW, Sep 11, 2019.
  1. AnneLW
    AnneLW Member
    118
    95
    California desert
    I see these on sale for anywhere from $250 to $400?
    Do the work?
    Are they legal?
    Any experiences to share?
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    $250 to $400 pays for a lot of gasoline. I would pass on this product and just carry the stock EVSE and look for a 120VAC outlet.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    As JB stated, your payback will Never happen.
    I did a calculation awhile ago based on 0.11 cents a kilowatt and ~$150 dollars, that worked out to more than ~5000 miles.
    So if you save your ~$300 dollars, that's like getting ~10,000 plus miles of FREE EV driving.
    Rob43
    PS, If you have a 240v outlet near your Prime, you can charge up in 2 1/2 hours for less than $50 dollars.
    #3 Rob43, Sep 11, 2019
  4. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The calculation should be the difference between the cost per mile of gas vs. electric? If you aren’t driving on EV, you are driving on gas, so the savings are the difference, not the cost of electric driving.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yep, I'm just basing that on the electric usage itself.
    Just edited that....
    Rob43
  6. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    One would have to recurrently charge at a Tesla destination charging station for a long period to recoup the costs. Long before then, management would likely ask such a person to leave unless routinely patronizing the facility.
    Tesla destination charging stations are usually installed to attract higher paying patrons, typically at hotels.
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Using the delta between gas and electric as the savings, for my area of the country (using your same $0.11 / Kwh) at $2.50 for gas (we're a bit lower, but this is conservative):
    Cost per mile to run on electric - 5 miles/Kwh, $0.11 / KWh = 0.11 / 5 = 2.2 cents/mile
    Cost per mile to run on gasoline - $2.50 per gallon / 55 mpg = 4.5 cents/mile.
    Running on electric saves you 2.3 cents/mile if you pay for the electric. To save $300, you would have to travel 13,000 miles solely on electricity provided by that adapter to recoup the cost. That's 522 full charges.
    If you get the power for free from the Tesla point or a hotel, then the savings are the full 4.5 cents/mile and you recoup in 6,700 miles. Still a long time and still 267 full charges.
    #7 jb in NE, Sep 11, 2019
  8. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
  9. bisco
    52,348
    that would be 20 gallons of gas in my pip! (y)
    vvillovv likes this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That will set sales on fire. Spend $40K plus on a car, get $50 of electricity as a bonus. I wonder if they deliver the car with a partially charged battery pack to recoup the loss?
  11. vvillovv
    4,324
    1,512
    NY
    With charger version 3 out nearly a year now eveyone should have seen this coming. The news was unsettling at best, but inevitable as lines for charger time are likely to start forming if Model 3 continues to grow it's sales. Even with the new pay as you go program.
    If a model 3 is the right fit as a daily driver, I think the new supercharger fee, although unsettling, isn't even close to a deal breaker in most cases.
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    Sorry, I have no idea, but even if it works and legal, I don't think it interests me much. I would have to drive over 100 miles to the nearest Tesla charge station. And what would they charge per kWh for non-Tesla owner even if they do let me use it? I bet it will cost more than buying a half gallon of gas to drive the same distance on EV.
  13. Robert vickroy
    Robert vickroy Junior Member
    Houston
    2018 Prius Prime
  14. Robert vickroy
    Houston
    2018 Prius Prime
    I have a 2018 Prius Prime Plug-in and my house electric meter was being replace by electric company. SO the 1st thing I plugged in after it was replace and at 0 on the meter was the Prius. Stopped AC and fans and lights but not 2 frig's. After car charged on 220v 1 hr-50 min, the meter read 8 KW and power company electrician said KW cost 8 cents. so rough cost for driving the next 25 miles on traction battery was around 64 cents.
