Anybody using-Advance Auto Parts Platinum AGM battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 30, 2019.
  1. ski.dive
    ski.dive Active Member
    899
    233
    Hutchinson Island,FL. Mt. Snow,VT
    There is also a 20% off 'on-line coupon' that will drop the price.
    +Specifications for Gen. 2 Prius
    Amp Hour: 41.0 AH
    Cold Cranking Amperage: 370 A
    Cranking Amperage: 510 A
    Negative Terminal Location: Top Right
    Positive Terminal Location: Top Left
    Reserve Capacity: 75 min
    Terminal Type: Top Mount
    Voltage: 12.0 VDC
    Link bellow
    Advance Auto Parts - Down for Maintenance
    49,576
    looks good, is it the right dimensions, terminals and vent?
  3. ski.dive
    899
    233
    It says it is a 'perfect fit' for the Prius.
  4. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    If it is local:
    The size may be correct, but also verify the position of the vent, that it can reach the current vent line so you don’t have to hassle modifying the fit. (I saw someone post they couldn’t connect the vent because it was on the other side. I haven’t seen a battery with a vent only on one side, but just in case)....
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,374
    3,228
    Madison, Wisconsin
    I've seen these in some customer cars occasionally.
  6. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Saves 30 bucks over the Toyota one. 3 year warranty. Pass.
    cyberpriusII likes this.
