Anyone bought this projector fog light Kit?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JStrenk, Dec 13, 2018.
  1. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    My factory foglights have a hole punched in one of the glass lenses and the insides are all corroded.
    I desired it was time to upgrade to projector lenses and bought this kit since the bolt in one are no longer available.
    But it came with no instructions and the website has instruction for about every other one install but these.
    Looks like it has two sets of mounting hardware. but the rings have a very sloppy fit.
    Anyone have any idea were to get started?
    49,492
  3. Riparious
    Riparious Junior Member
    Where did you get those lights, and how much were they? They look promising.
  4. Mendel Leisk
    38,727
    Google search turned up this:
    2010-11 Toyota Prius High Power LED Fog Lights Assembly Kit w/ Wiring
    Looks different than the pics though?
    There's an install pdf at the above link, but it seems like 90% of it relates to wiring that would be needed if you don't have the factory fog lights?? Also, it seems like a pdf created from scan of a print, that maybe came from a pdf, pictures very small and dark.
  5. RightOnTime
    RightOnTime Senior Member
    755
    1,625
    183
    Kidnapped in OC, CA
    They look very similar to 2 sets we had to replace with LED lights. One was shoved into the fog light insert - both had water inside them which then burnt out the bulb.
    Wish I had better news for you.
    iPhone ?
  6. JStrenk
    203
    101
    Ravenna
    That probably would of been a better buy. But here is the link from where I bought them:
    The fog light I have in there now , the lens cracked and water get in.
    I'll let you guys know how it goes with these when it warms up a little.
