Anyone Considering 16 inch Wheels?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dc202, Jun 25, 2009.
  1. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    I have a 2010 III and I am considering getting 16-inch wheels rather than 17-inch wheels as an upgrade. Any thoughts?
  2. Tideland Prius
    16,611
    Shouldn't be a problem. Use 205/55R16 as the tyre spec to best match the revs of the original 15".
    There's a TRD Sportivo wheel that I really like but I know I won't have any moolah (esp. since shipping from Japan is expensive)
  3. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Thanks. I am considering the Enkei, another nice wheel from Japan.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The size above is the tire I've seen on regular Honda Civics and they look great. What I like is the 55 sidewall is not too tall nor short. The 45 series tires are quite a short sidewall for a Prius.
    NorCalPrius67 likes this.
  5. Tideland Prius
    16,611
    Ooooh nice!
    mmhmm. 45 series is low profile. The IS300 had the same specs 215/45R17. The new Corolla XRS use the same specs too, ditto the old Matrix XRS.
    The nice thing is that we can just grab a set of alloys off a Corolla/Matrix. They're running 205/55R16. Just have to make sure that the bolt pattern is the same. That is, those alloys are your fancy.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I think when my 17" tires wear out I will go to 16" wheels with 205/55 tires. There are a lot of good wheel choices at Tire Rack and other places.
  7. kelmcw
    kelmcw New Member
    Penang, Malaysia
    Hi Guys, I am really new here... going to get my Prius within 2 mths time but already busy shopping for my 16" wheel. OEM comes with 195/65R15. Plan to get a Michelin Primacy LC 205/55R16 on it. Also did consider to get Toyota Camry 16" steel rim. Any comment?
  8. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I went from stock 15s to stock 17s. The stock 17s look nice but doesn't quite coast as well nor respond to acceleration inputs as quickly as the 15s. I have a set of OEM 16s from the Gen II that I've been waiting to install and compare...
    Kelmcw - I would think the Camry steelies would be a bit heavy and wouldn't quite look as nice with that hubcap look. There are some nice aftermarket 16s you could get without spending too much money.
  9. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Always worth considering the wheel weight, my UK Prius came with 16" wheels as standard but when I looked at replacing them with after market items they were all much heavier unless they were very expensive. Heavy wheels affect mileage and acceleration they are of course your unsprung weight. I dumped the trims and made centre caps from Toyota badges the 205-55-16 tyres protect the rims and the car drives beautifully
  10. arntz
    arntz Junior Member
    Australia
    i-Tech
    I fitted my 04 with 16X7" rims and cheap Federal 205/50x16 tyres. I went from 900 KM's on a tank to 800. I since replaced the tyres with Toyo Teo 195/55X16's, with an increase to 840 KM's. If I was doing it again I would look for the lightest rims possible, and would not increase the rim width to more than 61/2", or the tyre width to more than 195. On less than perfect road surfaces, there tends to be a lot of low frequency cabin rumble as well. On a Prius, the word Synergy even includes the light weight front alloy hubs, the lightweight rear suspension and wheels. Aussie Camry wheels won't fit the Prius due to the different wheel stud centering. Subaru wheels will in most cases. If you can live with the look and handling of the OEM's, leave it alone. I hope this helps you.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Is that a low rolling resistance tire? You probably know Prius uses LRR's for high economy.
    btw, I did the math, and the 16" tires are actually closer to diameter of 15" than are the 17's. At least by math anyway.
    btw, would like to see a pic of 3rd gen with nice 16's.
  12. kelmcw
    kelmcw New Member
    Penang, Malaysia
    Guys, I am so sad here in Malaysia. I written to UMW Toyota Malaysia... this is the respond that I got from them...
    ""...We write to advise that no modification can be perform on your current Toyota Prius that is of the original specification. Any modification carry out on your vehicle other than the factory fitted specification perform on your vehicle will void the warranty of your vehicle. Kindly refer to the Toyota Careplus Booklet, What is not covered on page 15 & 16 respectively. "
    Well, I think I will be leaving with the 15" for sometime now. Just change the rubber will do. :(
    But am just wondering, why the wheel radius is the same but....
  13. kelmcw
    kelmcw New Member
    Penang, Malaysia
    It should be... Michelin Primacy LC.
  14. blackcan
    blackcan Junior Member
    Tacoma, WA
    Ya'll....... You're driving a Prius not a 911! I had the same question, we found a beautiful 2016 Prius touring for my daughter. Surprisingly, it came with 15-in wheels, I'll be at nice 15-in Toyota alloys but 15-in nonetheless. I was considering the upgrade to 17 in but in the end I'm staying with 15 in on both her all season wheels and snow tires. You're buying a Prius for economy, you go to the 17-in wheels and I guarantee you're probably going to be losing 8 mpg! My son has already confirmed you already lose four MPG on 15-in wheels on a Toyota Prius c over the regular all season I think rather inexpensive Toyo all seasons I have on there right now. We're a multi Toyota Prius family... Lol. Just my two cents worth but I wouldn't go bigger than a 16-in if it were me.
  15. Mendel Leisk
    41,873
    Then there’s Toyota; I think they’ve lost their minds, with the 5th Gen. Up here in Canada the ONLY 5th gens for sale have 19” rims. And mandatory AWD. The plug-in version deescalates to 17”.
    our ‘10 Touring (CDN level) came with 17” rims. We get better mpg through winter, with 15” Michelin X-Ice. I was using Corolla steel rims for those, now upgraded to 2012-2015 15” Prius Plug-In alloys.
