Anyone else notice this.. (that has Canview)
Discussion in 'Gen 2 Prius Technical Discussion' started by p626808, Mar 8, 2007.
  1. p626808
    p626808 New Member
    292
    I had the car running for a little ride.. coolant temp was 142.
    I let the car shut down...
    It transfered the coolant to the tank.. I quickly put the car back in the "On" position. Did not start it..
    It pumped the coolant back in.
    Temp went down to 121..
    So.. I guess.. that there is about a 20 degree loss in temp when the coolant transfers in and out of the engine?
    It was about 32 degrees farenheight at the time I did this..
    Anyone else notice any similar readings?
    I would think they would keep it in the engine longer.. maybe until it knows the occupant had left the vehicle.. (by locking the door?)
    Thoughts?
    Scott
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yea, pretty typical to see a temp drop. Usually 10-20 degrees as you noted.
