Anyone ever had water in the spare tire well??
Discussion in 'Gen 2 Prius Main Forum' started by MagneticGrayIndy, Jun 11, 2008.
  1. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    :eek: So after reading a bunch of stuff about the Prius, and even though I've owned for two years now, I went digging around in the storage/spare tire area last week and found almost an inch of water in the well!!.. I dried it out, put it all back to together and thought... huh? Odd thing, nothing above the well was wet or looked like it had ever been wet. And the plastic bag with the never used spare tire hold down cables.. was wet on the inside!
    I don't live in New Orleans.. and the car is ALWAYS garaged. So I thought I'd just keep an eye on it. Today, I went through an automatic car wash and pulled around to vacumn and wipe off any excess water... Pulled the storage area apart to check for water and found 1/4 inch of water AGAIN!
    Again, nothing above the area was wet and the two drain plugs in the bottom were tightly sealed.. Wth???? Anyone had this problem? I'll call the dealerhip tomorrow and let them look at it.
  2. racerbob
    racerbob Member
    138
    S Florida
    Taillights, rear wiper grommet, or hatch opening gasket are possible leak areas.
  3. zsnark
    zsnark New Member
    Hi.
    I had this problem in my pre-Prius auto. The problem was with dried out tail-light seals. You'll want to get this fixed or you'll eventually get mold (or something) and/or your car might smell in the winter. Besides, you won't want to bail out the back of your car after each car wash or downpour!
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Your problem sounds like "Stump the Chump" on NPR's Car Talk.
    As I understand it, the HV battery is cooled by air drawn by a smallish fan
    through the grill on the pax side of the rear seat. (My understanding gets a
    little fuzzy here.) That same air is exhausted through a vent in one of the
    rear wheel wells. So there's a strong probability that there's some plastic
    duct work in there too.
    I'm suspecting that pieces of the ductwork have come loose and are at least
    partially disconnected. Two possible sources of the water. First, water forced
    into the wheel well vent during the car wash. Second -- but it would seem
    unlikely -- humidity laden air from the pax compartment condensing on the
    cooler metal work in the tire well.
    OK, if I win the T-shirt, I'd like size XL, with the red background to match
    my Barcelona red beauty.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    First remove the spare tyre and check there are no grommets missing from the spare wheel well.
    Get a garden hose after you have removed all the rear tub and cargo area floor then climb in the back with a torch and watch while someone pours water over the closed hatch and tail lights and watch for water flow.
    Do not ignore this, it will cause rust in all sorts of places including the roof of the car because there is moisture in the car all the time. Water vapour will condense on the inside of the roof if there is a pool of water in the spare wheel well. It will also cause window fogging.
    Water leaks into the rear of a car normally only happen after poor crash repairs.
    Do you have a towbar on the car?
  6. MagneticGrayIndy
    208
    Indianapolis
    Hmmmm... Since nothing above the spare tire well was wet (even after the car wash).. I even pulled off that big plastic piece where the "handle" is to pull down the hatch (dry as can be).. then I'm thinking it can't be from the hatch. I'm leaning more towards Rokeby's idea only becuase the water is low ... we'll see what the dealer has to say.
    Also.. two weeks after we bought it someone backed into the left tailight in a parking garage.. so I really suspect that the repair shop didn't fix something properly then, like maybe they left off a seal/gasket around the tailight. In fact.. the first time I noticed the water, there was also a bit of water to the left of the spare tire well under that tiny storage bin....
  7. Patrick Wong
    18,200
    6,471
    That is the most likely answer. Why not take your car back to the body shop and have them fix it for you at no charge? Usually these auto repair jobs have a workmanship warranty.
  8. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    A torch in the car while someone pours water in???? What will that achieve? Are you trying to weld something back together in the process? Yeah, I know, you mean a flashlight.....but that's not what we call them in the States...LOL!
  9. patsparks
    10,664
    567
    Well it's time you start using the right names for things then.
    It would be best if you use a torch which doesn't flash, well not flash all the time.
    Looks like MagneticGrayIndy has found the answer anyway.
  10. MagneticGrayIndy
    208
    Indianapolis
    so took the car to the dealer today and they couldn't see anything till the service manager crawled in the back with a "torch"! while they ran a hose over it. (come to think of it, it would have been nice if they washed it afterwards... anyway)
    found a leaking body seam?? just under top lip of bumper cover: caulked it, let it dry and retested. They think they've fixed the problem.. I hope it wasn't normal bathroom caulk! I'll let it cure for a couple of days then run it back through a high pressure car wash to see if that fixed the problem.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Its most likely the tail lights. If you open the hatch you can quickly see all the water runs down the hatch valley right over the tail light seam. Slightest leak there and you have water in wheel well. I bet if you pull all the panels away from the back of the damaged lamp you'll see a water trail below that light.
    Last 3 Nissan's I've owned all started leaking around the lens for some reason. I now preempt that on all cars I've owned by running a bead...a small very nice bead of clear caulk across the seam of the light assy in the hatch valley.Let it dry before closing hatch & problem solved. Good luck.
  12. keichline
    keichline New Member
    I have the exact same problem. Water pooled in the spare tire well, but no water damage (staining) to the carpet or surrounding areas. Quite a mystery. Will look thru the rest of the posts to see if a solution was mentioned that makes sense to try. My best guess thus far is related to water drainage from the roofline. Have considered cutting a slot in the drainage plugs in the meantime.
  13. Cip
    Cip Junior Member
