Anyone install a Tank heater ??
Discussion in 'Gen 3 Prius Fuel Economy' started by kswebb1, Dec 13, 2011.
  1. kswebb1
    kswebb1 Junior Member
    33
    Ohio
    Thinking of buying a kats tank heater for my prius.And I am looking for info about doing it from anyone that has.How did you install yours??Any issues??Would you do it again??Would you do anything any differently???
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
  3. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Ahh whah???
    51,141
    heats the cooling system fluid.
  5. kswebb1
    33
    Ohio
  6. bisco
    51,141
    wonder what the advantages/disadvantages over block heating are?
  7. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I have had these on other cars......they do not circulate the fluid.....just heat it up and it circulates it's self.....as would any other block heater.....however the wattage on this unit is much higher then the block heater you would get at the dealer. 400 versa 1500 of this unit.
  8. bisco
    51,141
    i think kats makes one with a pump that connects to the lower radiator hose.
  9. fotomoto
    5,629
    3,802
    So. Texas
    Ahh, that explains it. Another one of those mysterious devices to us southerners like engine block heaters, heated seats, ice scrapers, snow blowers, etc.
    :D
  10. bisco
    51,141
    sure, rub it in.:smow:
  11. gliderman
    gliderman Active Member
    751
    225
    I would trade my seat warmer for a/c ventilated seats any day!
    BTW, that heating unit would make a good cheap source of hot water in my garage shop.:humble:
  12. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
  13. bisco
    51,141
    interesting, i wonder how it compares to the instant hot water tap?
  14. walter Lee
    1,126
    376
    Maryland
    If the gallons per minute is high enough maybe
    it to could double as a tankless hot water heater
    for a log cabin in a pinch? :D
  15. Stocktonmanners
    Stocktonmanners aaaaaaa
    17
    hjkhljh
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Companies like Temro also make circulation "tank" coolant heaters. There are also heaters, typically used for industrial engines, that fit into the lower rad hose
    A thermosiphon heater has a couple of checkballs and springs inside. Its VERY important to ensure the cooling system is properly bled before first use, or you will fry the heater
    When you plug it in, the element rapidly heats the coolant inside the little tank. The hot coolant expands and pushes out past the top checkball. Then the top checkball closes and the bottom checkball opens to draw in cold coolant. The cycle repeats
    The better tank-style heaters have a thermostatic control too
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    We have a Webasto diesel fired heater on our boat. It uses a magnetically coupled impeller to move the coolant, and is good for 43,500 btu/hr. Would that do the job?
    Tom
