Anyone Install a third party BSM on their prime? (blind spot monitor)
Discussion in 'Prime Accessories and Modifications' started by Mavi, May 1, 2020.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So anyone install one of the many universal blind spot monitors on their Prius Prime? Curious to see how they turned out and how their sensitivity is.
  2. George W
    George W Senior Member
    911
    511
    San Antonio
    AldoON and CookinWithPooh like this.
  3. GSP_Prius
    GSP_Prius New Member
    2022 Prius Prime
    28B6D5A2-1005-4F80-A927-5108DB86CA2A.jpeg 08AC657B-DB62-482F-AA68-4583C36232C5.jpeg
    sensitivity good but need to find out which wires are for signal turns and backup light. Does anyone know which wires are convenient to tap into?
  4. GSP_Prius
    2022 Prius Prime
    So follow up on determine wires:
    I found the rear wire - needed for backup feature.
    See image attached.
    Might be tricky to know which wire is signal left or right. Was thinking to follow wires to the signal wires but would have to go under car to follow. Might do it or just test all the tires for power. Hopefully only signals are powered.
