Anyone install any sound deadening material on prius to reduce road noise?
Discussion in 'Gen 2 Prius Main Forum' started by goku9384, Jun 14, 2018.
  1. goku9384
    goku9384 Member
    47
    37
    Anyone install any sound deadening material on prius to reduce road noise? I'm looking to try this to reduce the road noise especially during highway driving. Anyone done this before? If so how was your experience?
    Princer likes this.
  2. qettyz
    qettyz Active Member
    181
    206
    Finland
    I dont have prius but i did my Auris doors. I added images here, you can find then from my profile.
    I was not waiting anything special, but happily suprised how much doors alone redused noise what studded winter tires make.
    But, i think that roof, doors and trunk should be done to make car really more silent.. Then you start hearing all kind a ratling what dash etc makes and then take everything part again:)
  3. qettyz
    181
    206
    Finland
    Cannot edit with phone: floor was left from list
  4. audiodave
    audiodave Active Member
    787
    268
    US
    Yes, covered as much as I could except the roof. But like to add some to that. These cars are tin cans. Gutted the interior and went to town. Probably added 30lbs but made a big difference.
    SFO and edthefox5 like this.
  5. goku9384
    goku9384 Member
    47
    37
    Which material did you use?
  6. bisco
    49,587
    quite a few. you'll find some threads with great pictures, detail, cost and post surgical satisfaction. all the best!(y)
  7. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    Yes … as Bisco said there have been quite a few that have done it myself including with very positive results. Search is your friend. I used Dynamat on Ema.
    Chris
  8. audiodave
    787
    268
    US
    Lot of a vinyl based stuff from Parts Express. Cheaper and lighter. But area's I wanted to make a big difference was Dynamat extreme. Doors and back corners sound solid. Have a custom sub in the corner and pricy speakers in the front doors. So wanted for better audio as well.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    I covered the entire trunk area it really helped quiet the total sound. Very quiet back there now. Got it off ebay it was cheap peel and stick. Anything beats bare metal. Got alot of towels in the hatch cargo holder above the spare tire.
    But if I wanted to take the door panels off I would move up to Dynamat. The door panels come off pretty easy.
    Dynamat in the doors would help more than anything. Just the clear plastic under the door panel helps alot. I had car installers replace the door speakers and they left that plastic sheet off the drivers door and now it goes clang when i shut the door. Haven't had the time to take it back. So just that thin clear plastic sheet helps.
    But Dynamat in the doors would be awesome.
    #9 edthefox5, Jun 14, 2018
    goku9384 and qettyz like this.
  10. audiodave
    787
    268
    US
    The holes from the outter door to the inner door closed off with dynamat really help. Plastic helped imagine dynamat.
    Nice covering in the back btw.
  11. audiodave
    787
    268
    US
    Looks like Partsexpress doesn't carry the vinyl based stuff anymore. But price is good for this stuff they carry. Screenshot_20180617-072839.jpeg
    kenoarto likes this.
