Anyone installed Sony XAV-AX1000?
Discussion in 'Gen 3 Prius Audio and Electronics' started by us_matrix, Sep 26, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    You're link just goes to the dash kit, not the radio....
  2. Leadfoot J. McCoalroller
    7,173
    6,721
    Pennsylvania
    2018 Prius c
    I installed its cousin, the AX-100 in our Prius c.
    From the steering wheel we can control volume, track skip forward and back, and change audio source between usb/am/fm etc.
    I had to do some extra wiring work to retain use of our car’s built in rear vision camera, and I chose to do some extra work to integrate the Sony handsfree microphone into the car. I mounted it in the factory handsfree mic location overhead.
    I never had to do anything with OBDII.
  3. Bobulator
    Bobulator Junior Member
    Atlanta
    Did you buy the optional steering wheel control unit, or did it work as is for the steering wheel controls?
  4. Bobulator
    Atlanta
    Did you pull the trigger on this unit? If so, how did it go? I'm thinking about the same unit. Did you have to buy the extra kit to use your steering wheel controls?
  5. Leadfoot J. McCoalroller
    7,173
    6,721
    Pennsylvania
    2018 Prius c
    I used the Axxess ASWC module. It's a universal converter but it came out of the box preset properly and included an appropriate harness for the car. All I had to do was physically mount it and connect it, no configuration or programming. It just worked.
