Anyone know if there is a way to tell if someone unplugged car?
Discussion in 'Prime Plug-in Charging' started by bear15, May 1, 2017.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    My question: Does anyone know if there is a way built-in the Prime (or other way) so we can know via phone etc. if the car is unplugged? I sometimes plug-in at a local car dealer for a few hours. Today when I went to pick up the car it had been unplugged with only a partial charge.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Yes, if you have the Advanced, it has an Entune feature that you can set for charge interruption notification, completion etc. Works great with my Samsung Galaxy S7. If you've locked the car, this feature also permits you to trigger the Remote Climate using your cellphone. One of the MANY advantages of the Advanced. Don't forget that you can push the button near your car's charge connection to lock the cable plug onto your car. Of course, any hoser dirtbag who disconnects a CHARGING vehicle and doesn't reconnect it, is probably not above vandalism, so be careful.
    priuscatprimeguy and dalcon95 like this.
  3. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    If you have an Advanced, the Entune app can sent you emails on whether the car has a Charge interruption, a Charge completion, a Charge restart after you sent a command to restart, and a Charge start if you came home and forgot to plug it in. You can also manage your charge of the car and see what the charge status at anytime. It will tell you the percentage of charge at the time and whether it is charging. I love the app and use it all the time. Also you can lock the charging cord to the car by pressing the button next to the green light at the plug at the car. If you are using the cord that came with the car, I am not sure what to do to stop someone from unplugging the cord from the 120V outlet. Hope this helps!
    #1 in Easley,SC
  4. dalcon95
    512
    653
    If you have the Plus or Premium, you are in the blind in regard to that concern.
    #1 in Easley,SC
  5. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Thank you very much for the rapid and helpful information. Unfortunately, we have the plus. If we lock the plug to the car, how do I unlock it?
    dalcon95 likes this.
  6. dalcon95
    512
    653
    Press the same button again to unlock.
    #1 in Easley,SC
  7. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Make sure you have your key fob nearby, when you trigger the lock/unlock button.
  8. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Are you sure the Plus has the button? I see the indicator light and a solid plug where a button might go, but I do not see a button that can be pressed.
  9. dalcon95
    512
    653
    If you don't see this button, you don't have it. Sorry if you don't.
    #1 in Easley,SC
    Prius from Dad likes this.
  10. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Many thanks for the picture. Yes, we do NOT have the button. I guess we will need to try some mods in the future.
  11. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    Is there there a way to have it auto lock once the chargers plugged in instead of pressing that button? If so, how? Sorry, I don't have my manual with me at the moment...
  12. dalcon95
    512
    653
    I know there is a way on the car, but being I don't use it, I would have to poke around or refer to the manual.
    #1 in Easley,SC
  13. dalcon95
    512
    653
    Here is what the manual says.
    #1 in Easley,SC
  14. fuzzy1
    10,479
    The Prime ebrochure shows it on the Premium and up, not on the Plus.
  15. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    Is this available on the premium models? Searched in the vehicle settings and couldn't find it...
  16. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    Nevermind, found it, thx!
  17. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    I have a Plus too and this is probably the one feature I would like to have ... I use Chargepoint at work and have it setup for text messages, e.g. when I unplug i get a receipt with the charge and a statement that it was unplugged, typically within less than 30 sec. So, if somewhere were to unplug me, i would get a message ... might now work in all places but more than nothing
  18. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Thanks to everyone that helped answer my question and much more. . .
    My question: Does anyone know if there is a way built-in the Prime (or other way) so we can know via phone etc. if the car is unplugged? I sometimes plug-in at a local car dealer for a few hours (not a charge point terminal). Today when I went to pick up the car it had been unplugged with only a partial charge.
  19. Tim R
    Tim R Member
    St. Louis, MO
    With the use of Chargepoint chargers, it can inform you when the vehicle was unplugged, the duration of the charge and KWH that was pushed to the vehicle.
    Team ChargePoint likes this.
  20. AnneLW
    AnneLW Member
    118
    95
    California desert
    I just discovered that after using Chargepoint for the first time (on the promotional card). Found a station at a Walgrens one block fro the movie theater. Just about exactly one charge away from home so that worked out.
