Anyone know what these diagnostics mean?
Discussion in 'Prime Technical Discussion' started by bonanzoo, May 7, 2021.
  1. bonanzoo
    bonanzoo Member
    64
    33
    Los Angeles
    MIL ON DTC P0335/P1340 INTERMIT. HOT SOAK/NO START
    MIL ON DTC P0335/P1340 INTERMIT. HOT SOAK/NO START ~|~REPLACE ENGINE AIR FILTER. ~|~FILTER DIRTY. ~|~ENGINE AIR FILTER REPLACED
    What is hot soak/no start mean? Never heard such a thing.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    What code reader did you use to get those codes?
    Have you checked the engine air filter to see if it is dirty?
    bonanzoo likes this.
  3. bonanzoo
    bonanzoo Member
    64
    33
    Los Angeles
    They are from a dealers record of a prime I’m about to buy today. I have no idea what hot soak means. I assume no start means it doesn’t start? I’m not sure to be honest
  4. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    It sounds to me like the previous owner let it sit in the sun on a very hot day and the traction battery got so hot that the car would not let it start up. If so, that's not good for the battery at all. Since it says it's intermittent, that suggests it has happened multiple times. This is definitely something to investigate. It's something I have never experienced here in FL. But I don't think I've ever let it sit all day in the summer sun without a windshield sun shade.
  5. bisco
    49,490
    how many miles on her?
    i can't imagine how dirty an air filter would have to be to throw a code. the engine must have been starved for air
  6. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    According to the source of all knowledge (Google) it sounds like on more than one occasion the engine was hot and did not start as opposed to the engine being cold and not starting? The reference to a dirty air filter is sort of self explanatory? I had a engine not start on my Gen 2 many years ago and it was fixed with a firmware update. No wrenches required. As suggested above, check the air filter and see if it needs replacing if it hasn't been recently.
  7. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Toyota had a TIS regarding this error... it's another car, but I am sure the reason is similar...
  8. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Never would have guessed that a camshaft position sensor would cause a "Hot Soak" condition....
    Battery? Sure.
    Fuel system? (Vapor lock) Yeah.
    Ya learn something new (though seemingly illogical) every day.
  9. ChapmanF
    15,615
    If it doesn't give a good position signal when it's hot, well, there's a hot-soak no-start. :)
    Fuel system vapor lock was more of a thing in the days of fuel pumps that lived on the engine, and sucked the fuel from the tank.
    Now they live in the tank, and push the fuel to the engine. Hard to vapor-lock that.
  10. bonanzoo
    bonanzoo Member
    64
    33
    Los Angeles
    99.8k quite a lot for a 2017
  11. bisco
    49,490
    hmm, tough one. i wonder if the dealer might know
