Anyone know when the next upgrade will be out for the navigation CD?
Discussion in 'Gen 2 Prius Audio and Electronics' started by funpilot, Jul 29, 2011.
  1. funpilot
    funpilot Junior Member
    73
    When will Toyota release the version beyond 10.1?
  2. healthizez
    healthizez Junior Member
    Salem, Oregon
    I just bought the latest upgrade (11.1) that came out Nov 2011 for $169. I have an 06 Prius and this is the first upgrade I've done. I haven't had a lot of problems with finding locations so waited until the price came down. The dealer showed me a chart that indicated how much the system upgraded for each year after 06. I also looked at the coverage area for the Northwest and then checked the difference in coverage with the new disc...it just about doubled the area covered.
    I had a lot of problems figuring out how to put the blasted dvd in so for others who have a Gen II: The navigation disc unit is found beneath the driver's seat. Access it by moving the seat all the way forward so you can access the front from the rear passenger floorboard. Take the plastic protection cover off (two plastic clips). Now there's a button on the left side of the unit that says "push". You have to push in and then to the right and the old disc comes our automatically. Insert the new disc and replace the housing. Now check that it works properly by checking the "map dvd" in the "Menu" portion of the navigation console...you can see "covered area" there as well.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Toyota updates the Nav DVD's every year around October. The number of the revision is the year. So the latest will be the 11.1.
  4. supra90
    supra90 New Member
    30
    florida
    2001 Prius
    Quick question will this new 11.1 Navigation DVD gets rid of having to manually hit the "I Agree" button ?
    thank you
  5. 69and98z28
    69and98z28 Junior Member
    SD
    Has anybody successfully created a "back-up" copy of the 11.1 DVD?
  6. priusNlondon
    priusNlondon Pingu 2.0
    49
    Somerset, England, UK
    ----UK----
    It's under the passenger seat for those that are in the UK/Japan/Aus :)
