Anyone knows how to pop out plastic cover front drl lights?
Discussion in 'Gen 3 Prius Technical Discussion' started by mygel, Nov 29, 2017.
  1. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Hi there, i need to remove plastic cover from front light, i think it´s a turning signal light just above the fog light? Thanks in advance. It is passenger side..
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    1. you can't remove only the cover/
    2. signal light & drl are one piece/
    mygel and Mendel Leisk like this.
  3. Mendel Leisk
    40,586
    Keep in mind too: if it was that easy, thieves would be taking them. Have a look at the attachment. Maybe you can avoid bumper removal, just take the front underpanel off and reach up, not sure.
    #3 Mendel Leisk, Nov 29, 2017
    mygel likes this.
  4. mygel
    mygel Junior Member
    46
    24
    Slovakia
    OK, i will see, i´m going to change oil this wknd, so i´ll try and post the result here. Thanks for the file. I think it should go without bumper disassembled or complete under plastic removal..
  5. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    The housing is held in place by 1 nut and several tabs;).
    Remove the plastic cover just below the light and you have easy access :).
    I did our 2010 assemblies a couple of months back and took about 15 minutes a side. There were chips in each cover:(.
    Good luck(y).
    mygel and Danny3xd like this.
  6. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Did it on saturday along with oil change, now i know the number of the part, i will order from ebay. The light has a crack and water inside causing mist from inner side. As Raytheeagle wrote, the light can be easily pop from inside after unscrewing one 10mm nut (it wasn´t tight, don´t know why) and pushing remaining 3 tabs. The plastic tabs look, like they are not very sturdy, they bent like a chewing gum:). Plastic undercover, several push pins and 10mm nuts
    j12piprius, RMB, Raytheeagle and 2 others like this.
