anyone knows how to reset brake system warning light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SamEgel, Jan 18, 2015.
  1. SamEgel
    SamEgel New Member
    Pompano Beach, Florida
    I charged the almost dead 12v with a slow charger and it is fine now. but immediately after charging the brake system light came on. i believe brakes are just fine, and want to reset the light and see if it will ever give again.
    anyone knows how to do that?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Disconnect the 12 V battery for a few minutes.
    If that doesn't work, see a dealer or independent shop.
    That light also indicates that the parking brake is ON, in which case it can be "reset" by putting the brake OFF. :)
  3. SamEgel
    SamEgel New Member
    No, the light I mean is not the parking brake light.
    It is the yellow color exclamation mark inside a circle and circle inside parenthesis.
  4. Patrick Wong
    18,200
    6,471
    You can reset the skid control ECU by using a jumper on pins 4 and 13 of the OBD-II socket. Do a search for the procedure and make sure you know for sure which pin is which before you attempt this.
    frodoz737 likes this.
