Anyone put a 2015 Prius v bumper on a 2012?
Discussion in 'Prius v Accessories and Modifications' started by Elizabeth Grubbs, May 25, 2025.
  1. Elizabeth Grubbs
    Elizabeth Grubbs New Member
    Cincinnati
    I’m trying to figure out if I can put a 2015 Prius v front bumper assembly and headlights on a 2012 Prius v, the main difference is the turn signal on the 12 is on the bottom bumper but not on the 15 so I’m wondering if there’s a way it can be done?
  2. PriusCamper
    PriusCamper Senior Member
    11,977
    4,868
    Pacific Northwest, USA
    This would be helpful information for PriusChat... Assuming you exhausted all existing posts on here via a google search with keyword 'priuschat' then maybe @V Sport Wagon knows the answer?
  3. Tombukt2
    Tombukt2 Senior Member
    11,988
    2,116
    Durham NC
    So is this the wagon or the the car with the dual LED projector headlights added in the mix then you're going to need the computer and all the nonsense that run those headlights along with the front bumper just curious if that's what you're running I wouldn't see why you couldn't the 2010 Prius here versus the 2013 Prius Persona that was here had the turn signals like you're talking about they would just plug up no problem. But then there's a bunch of nonsense that goes on with the headlights so you need to suss out what it is exactly you need those headlights are expensive so if you're just buying the front bumper I'm not absolutely positive that the generation 3 single projector open high beam headlight will fit there like it's supposed to it would probably go there but there may be a gap something in the space that it's going in I do believe I could be wrong but I don't think so for some reason so that's another question what are you doing for headlights with this conversion if this is not the dual LED dual projector then no worries obviously I don't know the v that well and hopefully won't have to
