Anyone put a mirror on a Gen 5?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Oct 24, 2025 at 10:39 PM.
Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    2,083
    540
    Alberta
    2024 Prius Prime
    XSE
    I've watched a few videos, but they aren't very good.
  2. Hammersmith
    Hammersmith Senior Member
    2,237
    2,246
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Reposting from when I answered your question three months ago.
    Here's a reasonably good video for the door panel. The one big thing he does wrong is use a power tool to screw the fasteners back in. Either do it by hand or carefully use a power tool on its lowest torque setting. The fasteners are screwing into soft plastic and will strip out super easy.
    Once the door panel is off, you pull off the black plastic covering the interior mirror connection point to expose the three screws holding it to the door. Everything should be self-explanatory at that point.
    The same guy has an extended version that shows removing the mirror. It's not the greatest, but you can watch it too. I do see that I remembered it wrong and the three bolts are actually10mm and not Torx like I was thinking.
    #2 Hammersmith, Oct 25, 2025 at 1:51 PM
    otatrant likes this.
