Anyone raised a Prius? I need 2 more inches of Ground Clearance!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by toanfam, Nov 4, 2007.
  1. toanfam
    toanfam New Member
    I bet this seems like a weird request, but I'm wondering if anyone has raised their Prius successfully...
    Just moved into a new house, but the driveway is a little steep and the car scrapes and gets stuck on the way up. I only need a couple more inches of clearance... Can anyone tell me if this is possible? Thanks
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    06+ comes with front bumper spoiler as standard to improve aerodynamics under the car. You can try to remove it. I am not sure how many inches you will gain. It might be enough and not scretch.
  3. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Bigger tires???
  4. johnford
    johnford Old Junior Member
    105
    Malvern, AR
    <div class='quotetop'>QUOTE(inventor00 @ Nov 4 2007, 08:01 PM) [snapback]534754[/snapback]</div>
    :) That's what I did. Went to 195 65's and gained a bunch. I live on a redneck highway... (gravel road) in Arkansas. I have heard in a thread here on PC that you can go up to 205's with no problem.....jf B)
  5. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Funny, I lowered my car.
    Wouldn't it be cool if ground clearance was like carbon offset credits? I could maybe sell an inch or so of what I'm not using...
    I had 195/65 15's on mine before I changed wheels, and there was a ample clearance inside the wheelwells. Now, it's lowered with the Touring wheels and 205/55-16's and I've encountered no problems. So I'd humbly suppose that 205/65-15's would fit...but they might be kind of heavy, too, and those tall sidewalls and big tires on the relatively narrow stock wheels might yield somewhat ---for lack of a better word--- 'flabby' handling(?) I definitely noticed it a bit with the 195's...higher cornering limits, but a bit more indecision getting there.
    dogfriend and GrumpyCabbie like this.
  6. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    If it's just a driveway, careful analysis of technique will get you a long way without changing anything (it's the only way a lot of cars survive in Los Angeles county, steep driveway aprons everywhere). Usually approaching the difficult spot from a different angle will do the trick. Give us a pic to work with?
    And I assume we're talking about scraping the front end? What part of the car is dragging?
    Edit: Hah... after writing that, I went back and saw that you ARE in LA County. I've been gone since 1993 but I remember a lot of tricks for these issues!
  7. hawaiiguide
    hawaiiguide Junior Member
    35
    Honolulu
    <div class='quotetop'>QUOTE(John Ford @ Nov 4 2007, 08:22 PM) [snapback]534760[/snapback]</div>
    We installed 205's because of the many potholes in Honolulu. The 205 Comforttreds smoothed out the potholes, made the car stand a little taller and improved the ride greatly. I think the 205 is the right size tire for the pri.
    Suggest you find a Pri owner with 205 comfortreds... the test drive will sell you on the change.
    richard :)
  8. dinesh75
    dinesh75 New Member
    Gaithersburg
    Hello there, I am in the market to buy a Prius.
    So how many inches did you gain by using the 205 comfort treads tires? I would love to get 2 inches too!
  9. Knobby Tires
    Knobby Tires New Member
  10. Knobby Tires
    Yes, there was a Prius for sale last year and someone had used air suspension to raise the entire body. The thread is still in here as of last week. I'll try and find it for you.
  11. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    I went wth 205/65/15 for my snow tires. Gained .5" which gets the Prius close to 6" ground clearance which is more than a lot of cars. More than AWD Subaru Impreza Sport Wagon
    Interesting aspect of going to the 205 is the speedometer is finally accurate, at least according to all the traffic radar speed signs.
    Winter mileage, rain, snow, wind, cold, winter gas with the 205's has been excellent, 45-48 mpg.
    And they look better. The 195's looked too small.
    When summer comes I'll likely get some high mileage LRR Michelin's in the same size for summer driving.
    But TWO INCHES puts the Prius at 7" and you are in AWD SUV range there. That's pretty high. You might want to think about modifying the driveway as most cars are in the 5"+/- range. Over time it is probably cheaper to get the driveway into spec.
  12. bisco
    48,974
    i wonder if toanfam has figured it out in 5 1/2 years?:cool:
    dogfriend likes this.
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    lol...
    Just sayin - with my GC sleeves you CAN go higher than stock height, at least OVER +1"
  14. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    I stiffen my rear axle to pull a trailer, by installing Firestone coil-rite air springs ( F-4136 ). Aired up to about 35 lbs, it lifted the rear UP all most 2 inches.The air springs cost about $ 85.00 for a pair. When I'm not pulling a trailer, I have about 5 lbs in it, it might be 1/4 inch higher; makes for a better ride.:)
    SFO likes this.
  15. Knobby Tires
    Airbagit.com is the other resource I was thinking of for lifting with air bag suspension.
  16. Knobby Tires
    ....Please explain for us newbies and wannabies.
    SFO likes this.
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    When I installed these: Ground Control - Part #:8070.01
    At even Mid-Point on the sleeve I was a touch above normal riding height. I ended up dropping it down to .5" from the bottom of the sleeve to get the height I wanted. But had I wanted to raise the height, it would have been super easy and given me AT LEAST +1 (prob up to 2")more drive height.
    SFO likes this.
  18. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Sweet, thanks for sharing! I've been looking for something like this. Will give it a try.
  19. Charles73
    Charles73 Junior Member
    los angeles
    Yes, I bought spring spacers from Autozone...it raised the car 1 inch all around.........just enough clearance to help out on steep driveways etc......
    Mambo Dave likes this.
  20. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The 185/65-15 24.5” diameter.
    The 195/65-15 25”
    The 205/65-15 25.5”
    So you go up a 1/4”-1/2”
    If it’s a gravel road, get a load 14 yeards of 1 1/2” gravel and fill in the spot you rub on your driveway, if you have a tarmac driveway, buy a few bags and spread them.
