Anyone recently get their inverter water pump replaced under recall?
Discussion in 'Gen 2 Prius Main Forum' started by Naskaf1, Aug 13, 2021.
  1. Naskaf1
    Naskaf1 Junior Member
    Detroit
    I see a recall under NHTSA safety recall for prius but i dont when i called toyota they said there are no recalls currently
  2. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Pretty sure that recall ended some time ago.
    See if it was replace by entering the VIN at : Track Your Service Records with Your Toyota Owners Account
    They don't last forever (around 100k miles), but the job is fairly easy. Best to buy the OEM part, as the aftermarket parts are hit or miss.
    Raytheeagle and PriusCamper like this.
  3. ChapmanF
    17,981
    If it was in fact a recall, and not some other kind of campaign like a warranty extension, then I don't think it ends.
    If your car is in the year and VIN range given here, and the original pump hasn't been replaced yet, they ought to.
  4. GrayRaceCat
    GrayRaceCat Junior Member
    It is a Recall, and it is valid until the original pump is replaced. Once that has occurred the Recall has been satisfied, and the normal replacement part(s) warranty begins on the new part. If the original pump has not been replaced, the Recall is still in effect.
  5. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Mine was replaced two years ago by an independent mechanic and Toyota reimbursed the mechanic for the charges
