Anyone remove center console on a 4th Gen Prius?
Discussion in 'Gen 4 Prius Main Forum' started by Mailman18, Mar 6, 2021.
  1. Mailman18
    Mailman18 Junior Member
    I am a mail carrier, been using the Gen 2's for 12 years on the mail route, work great. I'm thinking bout upgrading but wondering if removing the center console is as easy on the Gen 4's vs Gen 2's.
  2. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    My wife spilled a little coffee in her 2017 Prius cup holders and I found it quite easy to remove the entire center console, clean it up, and reinstall.
    Mambo Dave and Mailman18 like this.
  3. Mendel Leisk
    41,860
    He's long gone?
  4. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Was he a one-and-done poster? We seem to get quite a few of those, huh?
    Mendel Leisk and Reypac24 like this.
  5. Reypac24
    Reypac24 Junior Member
    17
    McAllen, Texas
    2020 Prius
    That is one long mail route...
    Mailman18 and Mendel Leisk like this.
  6. Mailman18
    Thanks, exactly what I was looking for. Must be some electrical connections(USB connection and 12V are on console) you can disconnect? Did center console run all the way under the shifter and park button?
    My 2008 Prius is still running strong, but has 180k mailman miles on it, those are hard miles. I want to buy a gen 4(probably new, uses Prius prices have gotten out of hand), but you can't really disassemble prior to purchase, so got to make sure 100% it would work for my needs.
    #6 Mailman18, Jan 17, 2022
    Mambo Dave likes this.
  7. Rbjr
    Rbjr Junior Member
    Nj
    It looks like the shift knob is attached to the front dash and the center console is attached to the floor...
    I preferr the gen2 center... Gonna look to replace the gen4 with a gen2... Ha
  8. Rbjr
    Rbjr Junior Member
    Nj
    Ok,
    Thank you to the poster who uploaded the instructions to unsnap the cup holders and back panel to get to the 6 10mm screws that hold the gen4 in place.
    I removed the 4th Gen center arm rest console ( did not like the smaller cup holders and how they removed, relocated the cup holders to the doors and rear folding arm rest ..)
    So unbolted the 4th gen, bought a used 2nd gen and it fits with 1/2 inch to the shift knob...
    Some diy modifications required... Had to drill and use self tapping screws to hold down the gen2 console in the back.... And er cut out the 12v and USB from the gen4 console and left in the sliding storage shelf of the gen2... Of course no hack like this is complete without T-Taps for hooking up the gen2 12v socket from the gen4 harness... White wire with black strip is the same in both... Only 2 wires for the 12v so the other wire was obvious.... Ha.
  9. Rbjr
    Rbjr Junior Member
    Nj
    The poster and directions from a different thread ..
