Anyone running the XG3600 filter?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by BellevilleMXZ, Jun 13, 2021.
  1. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    I thought I had read somewhere that these fit? I have not been under car to see if there are any clearance issues?
  2. Mendel Leisk
    41,457
    What kind of filter is this? Reading between the lines I’m thinking oil?
  3. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I'm using the 1/2in longer XG4386 because the bypass valve setting is the same as stock. I don't have a pic of the fitment but the shop that does my oil changes didn't say there were any issues with the fitment, even when I asked. In a couple of months when I go back for an oil change again, I'll see if I can snap a pic of the fitment
    BellevilleMXZ likes this.
  4. BellevilleMXZ
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Its a bigger filter. The one on it, is smaller than my lawnmower
  5. Mendel Leisk
    41,457
    A bigger oil filter I glean, from @jteran5.
    I did the conversion to spin-on (on my 2010), am using Toyota oil filter 90915-YZZN1, fwiw.
  6. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    The XG3600 will not clear. I took the XG3600 to the dealer for an oil change and told the advisor to try to install it when they work on it. Tech said he couldn't fit it. Had them use the XG4386 that I brought as backup. The XG4386 is 1/2in longer than stock but when you jump up to the longer 3600, it also gets wider and doesn't clear the bulge of the oil pan.
    Mambo Dave likes this.
  7. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Yeah, but it's still a Fram.
