Anyone successful in reducing ChargePoint minimum fee?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Coyotefred, Feb 15, 2022.
  1. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    So even out in the boonies where I live we're seeing some ChargePoint (and equivalent) charging stations coming online the last year or two. Our state utility has even underwritten a few. The problem: the $2 minimum per charge. The normal rate isn't too unreasonable (.50/hr during the day when I charge), so I'd be looking at only .79/charge if there was no minimum. With the minimum, I'm paying about 80cents/kwh, compared to 11 or so at home. And at that rate, the approx cost per mile is even higher than gas.
    I realize these stations aren't being built with our type of vehicle in mind, but still...seems the underlying rationale is to reduce overall gasoline usage....so shouldn't the pricing structure incentive that?
    'Just curious whether anyone was successful in convincing a provider to reduce the minimum charge? Even $1 min (which I see on some of the ChargePoint stations) would make this a much more reasonable situation.
    And yes I know you're not driving PiP for the $$$ savings, but still...
    Another reason I'm curious about this is that my employer (public community college) will be installing one of these in the next few months. It won't be paying anything (state utility is), and I'd like to convince them to have no or a $1 minimum charge. So I'd like to have some good arguments ready for that.
  2. vvillovv
    vvillovv Senior Member
    4,325
    1,514
    NY
    First, you'd need to know why some site owners charge $1 minimum and some charge 2.
    Than you'd have to understand the agreements between the site owner - your CC, the utility paying for the install and the contractor installing the unit.
    Think of it in terms or you installing a unit for public use as your home.
  3. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    A supermarket in our area recently installed two Charge Point stations using a great format: you must log in (via smart phone) but the first two hours are free. This is great, as another charge area in town is free but attracts moochers who plug in and leave their vehicles unattended for extended periods of time. Almost as bad as being ICED out by gas squatters.
