Anyone try these tail lights on their Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by xjustinx, Apr 14, 2011.
  1. xjustinx
    xjustinx Junior Member
    35
    san clemente, ca
  2. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    There was a group buy on this exact taillights.
    I have a set, its pretty good.
  3. cwc
    cwc New Member
    Killeen, TX
    I have a set as well, and they light up nicely. The only thing I was concerned about was the turn signal during the daytime, as there isn't anything to difuse the light from the exposed bulb.
    One thing to note, if you install the lights and the light piping running lights and LED brake lights light up opposite each other, the lights are not mis-wired. You just need to open the connection on the light that is lighting up wrong and fix the connection. There is a drum-style connection inside the light housing that can be connect 180 wrong. All you need to do is disconnect it, spin one side halfway around, then reconnect.
  4. xjustinx
    35
    san clemente, ca
    ^so should the led's light up when i brake or should they light up all the time?
  5. cwc
    cwc New Member
    Killeen, TX
    the light pipes are what should be lit up when you have your headlights one. the LED's that run between the light pipes are what light up when you press the brake pedal.
  6. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    I have them and love them. Look great and as usual for me, they look different than everyone else. Well except the people that have bought them as well but still won't be as common. Here's a pic of them on my car.
