anyone used cd slot phone mount on their prius?
Discussion in 'Gen 3 Prius Audio and Electronics' started by xcuter, Apr 29, 2013.
  1. xcuter
    xcuter Active Member
    303
    181
  2. Chaloney
    Chaloney Junior Member
    I have one of these. Works well. Used it for a couple years in my old car but the CD player was already broken. Haven't tried a cd in my prius--actually can't remember the last time I listened to a cd in my car...with my phone, pandora, and xm it hasn't been needed.
  3. xcuter
    303
    181
    great I ordered it! I choose this one because I like the location the phone will be in for navi and it will hopefully not obstruct the vents.
  4. Chaloney
    It blocks the vents partially but it depends mostly on how your phone is clamped in it (which depends on button location) and which way it is oriented. It does not block either vent completely, and at this time of year it get quite hot in the afternoons in Florida and I have not had any problems with inadequate airflow from the vent
  5. ewxlt66
    ewxlt66 Active Member
    535
    184
    Dana Point, CA
    Who will post a pic of their set up?
  6. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    I just got one for my Gen2. I love it! My only gripe is that it can get tricky if you need to remove it. Just take your time and it will come out without breaking anything.
    iPad ? HD
    Jeannine143 and ewxlt66 like this.
  7. ewxlt66
    535
    184
    Dana Point, CA
    Thx James!!
  8. came_to_party
    came_to_party Junior Member
    48
  9. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    I have a cell phone mount from proclip. My phone mounts next the cupholder. I tapped into the aux plug for charging power when the phone is in the mount.
  10. Jesse Melara
    Jesse Melara Junior Member
    39
    Los Angeles
    How did it come out? I want to order one but am worried it blocks the vents...how did yours come out??
  11. Mike500
    Mike500 Senior Member
    2,593
    758
    I don't know about the regular Gen III Prius, but the Prius"v" has this useless "card slot" for business cards that could have been much better used for a cup holder.
    An "L" shaped piece of aluminum with a cheap phone mount would be nice there, but you'd have to train you left hand.
    Just a thought.
  12. xcuter
    303
    181
    It worked out well.
  13. lichenpan
    lichenpan Junior Member
    Chino Hills, CA
    Have you guys tried Steelie mount? It works really well. I use it to mount my phone right in front of steering wheel.
  14. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    Looks cool - but not sure about having the piece stuck to the back of the phone like that :)
  15. ratedK
    ratedK Junior Member
    Indianapolis, Indiana
    I found this simple IdeaWorks phone/gps mount at Frys Electronics for <$10. Looks like it's available on ebay & newegg also. Lets me put it right where I want it on top of the steering column within reach. Doesn't effect the tilt/telescope of the steering wheel. Looks like it would work well on the dash too.
    Works great with my S4, and running a wire to it was a breeze down to the plug under the center console. I also just transplanted my Escort Smart Radar display from my previous vehicle - mounted just to the right of the phone, along with a Bluetooth ODBII module that shows RPMs/battery temps/Reverse Beep/Instant mileage on the phone with the Torque App.
    Ideaworks JB7050 video review:
    Pictures of ratedK's phone mount: Prius Photos by ratedk | Photobucket
    DSCN0663.JPG 2014-07-21 07.41.59.jpg 20140720_134224.jpg DSCN0657.JPG DSCN0658.JPG DSCN0659.JPG
    KananDume likes this.
  16. James4455
    James4455 Junior Member
    72
    San Angelo, TX
    I have a cd slot magnetic mount for my Samsung Galaxy Note 3. Overall I would rate it about a 8. Downsides are that the Note 3 is just a little heavy for the magnet and will let it slide over moderately rough roads. I don't think this would be a problem with lighter phones. Also, the setup obstructs the ac grill somewhat and the head unit slightly. Still, I'm happy with it. And no it doesn't harm the cd player.
  17. Liquidsilver
    Liquidsilver Junior Member
    West Palm Beach, FL
    This thread was handy when I was looking for a mount, so thought I would add my opinions. I purchased the "TechMatte MagGrip CD Slot Magnetic Universal Car Mount Holder" from Amazon for $10.99
    It fits well into the CD slot once tightened down. I used both styles of plate, the one that fit between the phone and case, as well as the adhesive style. Neither phone slips once put in place. One things to note, the magnetic is so strong it can adjust the angle of the magnetic holder when you are removing the phone from the mount. I got in the habit of pulling the phone downwards where the motion bottoms out, and it has prevented this issue further.
    The thing most people complain about is the thumb screw on the bottom of the mount blocking the dash. And of course, it is a problem with the LCD screen on the Gen 3 Prius. But a $1 bolt from a hardware store can solve this. Get either a M5x20, or a 10-32 x 1 and it should fix the problem. If you have a hacksaw you can fine tune the length of the bolt even more. The mount will not be as quick to remove, but I never foresee a need to remove it as this point.
    The is the mount with the factory thumb screw blocking the LCD. It was annoying with NAV because it does a great job of blocking the upcoming street names.
    This is the mount with the new $1 bolt. The bolt is now short enough to not block the screen. It still has about two threads showing, and I may shorten it a little with a hacksaw when I have some free time.
    All in all I would recommend this mount WITH the bolt replacement.
  18. caymandiver75
    caymandiver75 Member
    171
    91
    Northern VA
    2019 Prius Prime
    I use the Keno air frame and love it!
    Redbot likes this.
  19. Lilpig
    Lilpig Junior Member
    16
    new york, ny
    2014 Prius Plug-in
    I tried and returned the CD mounts, I ended up going with shifter mount holder called the Nimbus Mount. I got it from amazon
  20. Jeannine143
    Jeannine143 New Member
    NY
    Does anyone know if you have to remove the CD’s before inserting the phone holder? Also I wonder if you can play the discs while it’s inserted?
    I found one on Amazon that I’ll probably get Not sure for Prius. I’ll share the pic for whoever is looking for ideas.
Loading...
