anyone uses Blink charging station succesfully?
Discussion in 'Prime Main Forum (2017-2022)' started by ltlurker, Jul 2, 2021.
  1. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    Now that some of us are returning to work. I was excited to start using the charging station at work that is FREE. It's a blink charging station and the plug fits perfectly fine except for that it doesn't actually charge the car... indicator on the blink system says it's plugged in and prime dashboard shows charging door open and that's about it.. am i doing something wrong?
  2. schja01
    schja01 Senior Member
    1,821
    1,208
    Chicagoland
    2024 Prius
    Limited AWD-e
    Are you sure you have the Prime set to “Charge Now”? The green LED on the charge port should be solid green when you plug in. If it blinks you have an active charge schedule.
    Valiant V likes this.
  3. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    yes, setting is on charge now. green light at the charge port does not turn on or blink
  4. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Probably need an account or an app. Nothing is free. Or consider it this way, if it’s “free” then the product is YOU.
  5. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Do you need to enter a "Blink Code" to initiate?
  6. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    i do have the card / code to active. it's "free" for office tenants of the building and pay for a parking spot. ive seen tesla being charged there and just want to join the club for charging
  7. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    You are not the OP, how would you know it is not free to him/her?
    I get charged free at work, yes 100% completely free!!!
    Stop lecturing for things you are unsure.
  8. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Some of the charge connectors need an extra shove to get them completely into the car's receptacle. This one might need that extra push--wipe it clean first if there is any dirt on the outside of the cylinder. You should see the green LED at the car's charge receptacle as well as any indicator on the power supply, and the blue LEDs on the car's dash.
