anyone using 55w HID ballasts?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by putty, Mar 14, 2010.
  1. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    I just installed my ddm 35w 4500k hid kit on my car, things were great until I saw a bmw or some nice car with much more light, now I want to upgrade somehow, I'm wondering if the 55w kit is going to be too hot for our projecters? anybody using them yet?
    thanks
  2. ajc
    ajc Member
    340
    38
    pa
    No, I have the 35w HID 6000K from hidextra.com and mine are very bright. Who did you purchase yours from? They should be much brighter than the stock halogens.
  3. hlkc
    hlkc New Member
    229
    US
    Yes, ajc and I have the same 35W kit and it is very bright. I can't imagine anything brighter then that is ok to use it in the road.
  4. Prius Happy
    Prius Happy New Member
    114
    Irvine, ca
    I dont think 55w will be a problem... normal halogens burns about the same wattage.
  5. hlkc
    hlkc New Member
    229
    US
    If I recall correctly, I don't think it's the wattage problem. I read somewhere and it said it is the heat the 55w generating.
  6. Prius Happy
    114
    Irvine, ca
    Oh is it... hmm. I gotta look that up too then lol
  7. HaroldC
    HaroldC Junior Member
    NYC Area
    I also just received and installed the same kit from DDM. I was expecting a more white color, but the light is white with a little purple in it. The color is similar to 6000k bulbs. This would be reduction in the lumens from the kit compared to an OEM 4300k setup. I've already emailed DDM and they want me to send pics of the lights.
    I would be a little cautious using a 55W kit in our housing. There is not too much volume in the housing to dissipate the heat generated from the 55w bulb. Not sure how well ventilated the housing is, didn't get a chance to inspect the size of the vents.
  8. putty
    putty Member
    147
    39
  9. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
  10. hlkc
    hlkc New Member
    229
    US
    Thanks for the share. I've 2 comments
    First, I like Philip and I do like the QC and their design. With that said, if my current one blow up one day soon, then I will sure to get such kit and try,
    But on the other hand, I am concern about 55W instead of 35W. Not sure where I read it, but if I remember correctly, 55W generated too much heat for our housing. If anyone using a 55W for a while, please let us know.
  11. putty
    putty Member
    147
    39
  12. putty
    putty Member
    147
    39
    you know, I read the same about the heat but Philip's bulbs don't over heat like Chinese knock offs, but hopefully I'll get plenty of light from these at 35W
  13. leeb18c
    272
    202
    SF Bay Area
  14. putty
    putty Member
    147
    39
    here's some bad pictures of DDM 4500K vs PHILIP'S 4300K HID kits (both 35 Watt), I took the pictures 30 feet away from the garage door with the camera set to F6.9 @ 1/4 shutter speed...............
    DMM is on the drivers side, the 4th picture,
    PHILIP'S is the 5th picture passenger side,
    Looks like Philip's is brighter, plus the DDM has a slight purple going on.......
    Big price difference, the PHILIP'S kit was $280 and the DDM only $40
  15. hlkc
    hlkc New Member
    229
    US
    Thanks for sharing the pictures. What do you like? Are you going to keep the DDM or change it to Philip? If Philip please keep us update regarding the heat since it is 55w.
  16. putty
    putty Member
    147
    39
    both kits are 35w, before I found the philips kit I thought a 55w kit was the only way to get more light, so I'm happy with the philips
  17. hlkc
    hlkc New Member
    229
    US
    Good to know it is 35w as well. Since you said "I'm happy with the philips" can you share with us why? Is it brighter, the color or?
  18. putty
    putty Member
    147
    39
    I was looking for brighter, more light and the Philip's kit did it, the ddm kit was too blue/purple (and dimmer) for my taste also
  19. stlprius
    stlprius Junior Member
    16
    Missouri
    What is the exact part number for the light kits? Are they hard to install?
  20. alexprius
    alexprius New Member
    Chicago
    I had both the 55w and 35w (6K) from DDM. The 55w provides noticeably more light then the 35w. You are safe to use 35w, but for the 55w I would strongly suggest getting a relay harness so that you don't fry your OEM harness. It's a simple install (you run power directly from the battery and the OEM is only used for on/off switch) and it is the best way to ensure that your ballast will always get a strong power supply (they will last longer).
    Let me know if you have questions, I have done a number of HID's on all of my cars and always used a relay harness.
    Also, there is no reputable companies out there that produce aftermarket HID kits.
