Anyone working on a plug-in mod for the C?
Discussion in 'Prius c Accessories and Modifications' started by rwiggins951, May 3, 2012.
  1. rwiggins951
    rwiggins951 Junior Member
    Cleveland OH
    I have been very happy with the mileage of my Prius C thus far. Still, I am interested in the possibility of converting this car to plug in. Anything that would make the C less suitable for this conversion than the other Prii? Anyone working on a kit now?
    Thanks,
    Rod
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    I am helping to work on one.. biggest limitation is space for the battery packs.. you can only put in so much..
    looks like it'll have to be a 3kW system.
  3. Mik1
    Mik1 Member
    333
    Houston, TX
    How much of a range 3kW system will give? Might be a stupid question, but, I was looking at toyota's info and it seems that the output of the original battery pack is about 43% of motor's output. Sure there is a reason behind it. If the space is not an issue, do you think that the bigger systems are possible?
  4. SquallLHeart
    826
    247
    San Jose, CA
    if you want to sacrifice any storage space for more battery packs.. it'd improve.. though you also will have to start factoring in the additional weight.
  5. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    I'd just like to have the all electric option, for the daily commute and the hybrid system for those longer trips that exceed the battery's range. Best of both worlds. I want it all...:)
  6. SquallLHeart
    826
    247
    San Jose, CA
    did some disassembly this morning.. only to find out that where I need to tap into the HV supply to install it the way I want... requires you to pretty much pull out the traction battery to access it.. yeah.. it's a PITA..
    hmm... back to the drawing board..
  7. Neilb9
    Neilb9 Million Mile Driver
    22
    Kauai
    Anyone thought of using a 120 V charger to top off the HV battery at night? I know it's only .9 KV but wonder if you could pick up a little mileage by starting each day with a topped off battery. Any ideas?
  8. SquallLHeart
    826
    247
    San Jose, CA
    i would imagine topping off the stock battery would be detrimental to its life. it's NiMH afterall...
    also, the engine still needs to warm up during first initial start-up.. and that excess energy needs to go somewhere.. it sure would be a waste if it wasn't being used.. so most times it's better to drain the battery down at the end of your trip (EV mode is useful to do that).. that way when you start-up again, the battery can charge up while it's warming up.
  9. Mik1
    Mik1 Member
    333
    Houston, TX
    I don't use a lot of my trunk space anyway. To me my PC is just a "home-work-home" commuter, that's why I was curious whether it is possible to install additional HV battery pack and how much of the additional ev-range/torque will I get?
  10. formula
    formula Member
    320
    32
    CA
  11. SquallLHeart
    826
    247
    San Jose, CA
    pretty much the recuperation costs for a PHEV conversion takes a pretty damn long time...
  12. mremaximus
    mremaximus "I can't wait to start hammering people" Bubbles
    98
    From parts unknown...
    Some states are offering a tax credit for PHEV conversion. UT is offer in up to 2500.00 so I've been thinking about it.
  13. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    I like the idea of adding a plug-in to bring the factory NiMH to it's safe max of 80%-ish charged, however I don't like the idea of adding 120 pounds of extra batteries. If anything, I'd want to replace the NiMH with a LiFePO4 or similar to improve energy density without adding mass to the car.
  14. Vince D
    Vince D New Member
    Montreal, Quebec
    So, still no conversions? Since that the sales of the Prius + are going well. Maybe that they will annonce a Prius C plug-in for 2014 model...
  15. bisco
    49,490
    there is another thread here where someone is adding a 3kw pis kit to there C.
  16. Netineti
    Netineti Member
    98
    36
    North Carolina
    Do you know the thread?
  17. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    As a very new owner I'm not looking to mod just yet, but some day I'd love to imagine popping in a very powerful battery for plugin charge ability and get a good 10 or 20 miles from electric only. However, I don't know how Toyota's computer would accept the change. How would you get the system to accept EV mode above 25mph?
  18. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    I normally leave 5 or 6 bars when I park and after warm up it never goes past 7 bars?
  19. godai
    godai New Member
    They make a 4 KW kit for us at Plug-In Supply.
  20. bisco
    49,490
    yes, someone here is installing it.
