Anything wrong with jumping the new Priuses directly from 12V terminal?
Discussion in 'Gen 2 Prius Main Forum' started by primuspaul, Jul 31, 2017.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I always hear the stuff about needing to find the positive terminal under the hood to get the +, and then as usual you can use any chassis component for -. Is there a reason you can't just use the + terminal in the trunk?
  2. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    No reason you can't.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    It's difficult. Why would you?
    Have to pull the trunk apart then pry off the red plastic cover and then unbolt the positive assy
    Besides jumping a Prius is a death sentence.
    49,597
    the new priuses have the battery under the hood.(n)
  5. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    I could be wrong .... but I do not believe the 12v battery does anything but power the assessors. Now, it the HV battery is charged, and only the 12v is needed to power the computer ... perhaps it would work???
    Personally, I think it would be safer to walk outside in an electrical storm in a suit or armor than deal with the Prius electrical system. Isn't the HV battery something like 460v?
  6. NavyLCDR
    188
    120
    Stanwood, WA
    The 12v battery is needed to go from the off condition to Ready mode. When the car is turned off, the HV battery is disconnected by a relay. The 12v battery is required to energize that relay to reconnect the HV battery. Therefore if the 12v battery is dead, a "jump start" is required to get the car into Ready mode, at which point the HV battery does take over and the 12v battery is not really needed but does charge until the car is turned off again.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    If the 12v is really low or dead, then it's very difficult to reach the battery because the hatch won't open electronically. For most folks, it's MUCH easier to reach the hood points rather than doing the contortionist act to reach the manual switch/lock. :confused:
  8. bisco
    49,597
    even in the new priuses?
  9. Mendel Leisk
    38,794
    OP's question is vague. He's posted in 2nd gen forum, and says "new priuses" and "+ terminal in the trunk". So who knows.
    The thing I keep thinking: you shouldn't need to be regularly jump-starting the car; if you are, it's time replace or recharge the battery.
  10. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I have a Gen 1 Prius so I don't have that particular feature. However, it was the cause of much confusion for me the first time I wanted to jump my Prius, since I was looking for a positive pin under the hood, but then discovered this did not come into existence until the Gen 2. That's why I was wondering why they did this with the Gen 2 and up. The only thing I can think of is:
    1. To avoid taking off the positive terminal off of the battery.
    2. To avoid having to take the cover off in the trunk.
    3. Conventional car users are used to having it under the hood.
  11. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    4 if the battery is dead, as mentioned earlier, it's a pain to get access to the battery
  12. bisco
    49,597
    my head is spinning.(n) a new prius would be 2017 generation 4. a 'newer' prius could be anything from 2004-2017.
    Raytheeagle and Mendel Leisk like this.
  13. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    This probably refers mostly to Gen II.
    I always use either my key to open the trunk or the lever by the driver's side door. Is it different on a Gen II?
  14. Tideland Prius
    16,170
    You can directly jump the 12V battery. We've done it in the Prius. We tried the hood thing and it wasn't enough to charge the car but jump it directly and it was able to turn on and run the car after a few minutes of charging.
