Anyway to get the car to charge the traction battery idling?
Discussion in 'Gen 3 Prius Technical Discussion' started by cossie1600, Jun 21, 2010.
  1. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    I know car likes to shut off at 3-4 bar, but what if I want to keep the battery closer to full in order to get more power. Is there anyway to tell the computer to keep engine running?
    Thanks
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I don't think so. You can trick the car to keep the ice running but I believe when the battery has had enough the ice just idles.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    Uh, two things:
    1. The battery isn't really "full" even when you see all green bars. The software tries to keep the SOC (state of charge) between 40 - 80%. "Full" is approximately 80% charge.
    2. Power in the electrical sense, or power in the sense to propel the car? Neither one is a direct function of the SOC.
    It is best just to let the car worry about maintaining the SOC. It was designed to do a really good job of it. :madgrin:
    2 people like this.
    49,408
    when i'm idling for a long time and the battery goes down to one purple, it tells me the car won't charge unless i put it in park. when i'm in serious creep and crawl traffic, it goes to one purple and pretty much stays there until we get moving again. doesn't seem like it would be very good for the battery. fortunately, it doesn't happen that often.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Do you have the car in N when that happens? The car cannot recharge the battery when in N because the two MGs are electrically disconnected from the system. You need to be in P or D (or B or R) so the car can recharge the HV battery when needed.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    To add to dogfriend's comments: the Prius never really deliberately "tops off" the SOC on the chance you might have a long down-hill stretch using "B". I've done this a few times on trips down mountains and it's the only time I've seen the SOC indicator with all bars lit. I think at some point, the car will stop charging the HV to prevent an overcharge by "bleeding off" the regen process. It's rare, but can happen in certain circumstances.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    force charge the car... shrug....
    keep the car ON.. in D.. hold the brake down and apply gas. the engine will spin generating electricity for the battery.. once the battery is full the engine will turn on... (and won't turn back on till the SOC drops)
    i used to use this method for rally courses.
  8. bisco
    49,408
    yes, in neutral when i'm idling and i put it in park when it tells me to. i try to keep it in park when i'm in a live parking etc.
    in stop and go traffic, naturally, it's in drive and i don't get the warning, but it still goes down to one purple sometimes and the engine will kick on but only for a minute, not for any substantial charging. i think it kicks on as i apply the accelerator and off as i let off the gas or hit the brake. it's fairly random as i'm moving and slowing in many different speeds with the traffic.
  9. icarus
    icarus Senior Member
    4,884
    976
    earth
    The car and it's battery control system is way smarter than most of it's users. (Good thing too) In the off grid solar world, the biggest cause of battery failure is "operator error"!
    Let the car do what it was designed to do. 55 mpg, along with great driveability and great longevity (Pruis' in cab service have seen 500,000 km, better than 300,000 miles)
    If it aint broke don't fix it.
    Icarus
    PS Full bar battery gauge or low battery gauge will have no effect on the amount of HP you can put to the wheels. Why would you care in a Prius anyway? By running the engine strictly to charge the HV battery is almost the least efficient thing you can do.
  10. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    It does not have to be full bar.
    Just select PWR mode and go!
    As V8Cobrakid wrote, you can charge the battery by holding the brake down and applying gas in D, but it is very wasteful solution.
    Ken@Japan
  11. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    IMO its not a good idea to put the car in neutral while at a stop,:cool: even in traffic, because it will not charge the batteries. Its probably a much better idea to put it in park if you dont want to hold the brake pedal. Plus it takes to same amount of effort to shift it in drive whether it was in park or neutral..., save your batteries and avoid the warning signs and shift it into park when you stop. :cool:
  12. bisco
    49,408
    lesson learned, thanks. just wondering, does anyone know why it won't charge in neutral? i'm assuming the engine is not allowed to run, but why?
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The engine can run in neutral. It can't start, nor can it shut off. It will keep doing whatever it was doing when you shifted into neutral.
    By law cars are required to have a neutral setting which disengages the drive system from the wheels. Since the mechanical parts of the Prius are always engaged, the only way to disconnect is to turn off the fields to the electric MGs. This is why the Prius will not charge in neutral.
    Tom
  14. bisco
    49,408
    makes sense, and thanks for the prompt reply!;)
  15. cossie1600
    898
    92
    CT
    Here is my question. Does the car put out more power at WOT with the battery full (80%) vs depleted (20%) since the battery don't get the chance to push more juice into the electric motor?
  16. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Yes. but it's unlikely you'll get your SOC down to 20% unless you purposefully try really hard.
  17. qbee42
    18,058
    3,074
    Northern Michigan
    Yes. Try climbing some of the big mountain passes out west. Once the battery runs down to the low limit you are running on nothing but the gas engine. The poor little beast works pretty hard then, especially with the smaller Gen II engine.
    Tom
  18. Bob64
    1,540
    92
    Virginia
    While "force charging" might be useful for races, why would you bother wasting the gas for a tiny boost? (yes, force charging reduces your overall mpg when compared to normal driving). The battery isn't massive, it can only hold a tiny charge.
  19. cossie1600
    898
    92
    CT
    Need all the power I can get when I do TT or autox. I guess I do have to force charge it. Usually the battery is at 2 or 3 bar after 45 sec boost, sucks
  20. Flaninacupboard
    1,297
    213
    Midlands - UK
    You could add a PHEV kit and only switch it on 5 minutes before the race?
