Anyway to open all doors with smart key?
Discussion in 'Gen 3 Prius Main Forum' started by MPGMachine, Jun 10, 2012.
  1. MPGMachine
    MPGMachine Junior Member
    30
    Los Angeles
    Kind of annoying open your door, then hit the unlock button. Is there an option or some hand motion to unlock both doors when you grab the handle?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    - try skipping to the 1:34 mark
    AlinaH_RD and xliderider like this.
  3. MPGMachine
    30
    Los Angeles
    Brilliant! Thanks!
  4. ES44AC
    ES44AC C.A.U.S
    319
    77
    Nice video but I can't accomplish what it shows by holding all the keys down and releasing them. Can't imagine it's only a feature on a 2010 but I can't do it with my 2011. :(
  5. pghjerry
    pghjerry Junior Member
    58
    Dodge City, KS, USA
    2015 Prius c
    This was one of my biggest aggravations so far with my 2012. This worked like a charm, Thanks so much!!
    On the 2012, just sit in the car (dont press start). Hold all 3 buttons on the remote, and after like 5 seconds, it will show you a picture of the car with all 4 doors open on the MID.
  6. El Dobro
    El Dobro A Member
    6,978
    3,213
    The owner's manual says the dealer can program it.
  7. El Dobro
    El Dobro A Member
    6,978
    3,213
    For kicks, I tried the procedure in the video on my 2011 and it worked just fine.
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I think you might be able to do it by only holding down the lock and unlock buttons on the remote.
  9. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Well, I've just done it on my 2010 (and boy am I kicking myself for not doing it before).
    Sit in the car with the power off.
    Hold down Unlock, lock and panic at the same time.
    After 5 seconds it'll flash up a picture on the display of the car with all 4 doors open.
    ratwayd likes this.
  10. fernside
    fernside Junior Member
    Nashville, TN
    Wow, thanks for posting this question! Guess I should have searched the site before. My dealer did not know about this...disappointing. Bought my Prius a YEAR ago. Glad to know this is possible!
  11. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Great to know, thanks. For my wife and daughters they always program their doors to open driver only. If your going to your car at the mall or somewhere other than home it's probably safer to keep the other 3 doors locked when your alone.
    Bgmacon likes this.
  12. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Sad, but many dealers(salesmen) don't know the basic things they should know about the products(cars) they sell:unsure:.
    AlinaH_RD likes this.
  13. markabele
    5,084
    1,782
    Nebraska
    I would hope at the very minimum they make every salesman read the entire manual of each car they may sell. Pretty unlikely that happens in real life.
    SoCalBPrius likes this.
  14. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    cwerdna, or should I say Andrew ;), thanks for the tip. :)
    Worked on my Camry SE, though it felt like I had to hold the buttons down for much longer than 5 seconds. Will do my wife's Prius later.
  15. SoCalBPrius
    563
    118
    SoCal
    Smart key is so ingenius & convenient that it should be standard on all cars:sneaky: as it's such a chore now to get out my keys to open & start my other cars:p.
  16. ES44AC
    ES44AC C.A.U.S
    319
    77
    Hi El Dobro,
    Well I'm glad it works on your 2011 but it doesn't work on mine. I see the graphic come up that shows all 4 doors open, at that point I let go of both buttons or all 3 ,doesn't seem to matter, and nothing has changed. I have alternately tried to release the UNLOCK button when I see the graphic but that doesn't help either. Or I have tried to release the buttons when the graphic goes out, still no joy. Sorry but I can't seem to make it work. :(
  17. El Dobro
    El Dobro A Member
    6,978
    3,213
    Do all the doors unlock when you hit the unlock button twice?
  18. ES44AC
    ES44AC C.A.U.S
    319
    77
    Yes they do! That part never fails but it'd be nice to have it done when I hit the button once. I have tried again and again doing all sorts of things like holding the buttons in longer, all that does is cycle back to the one door open graphic and then the four doors open and so on. I have also tried it when the power button is lit up but not turned to READY. Again no joy. I am stuck!
    Maybe I should try my other set of keys to see it that works?
  19. El Dobro
    El Dobro A Member
    6,978
    3,213
    Give it a shot. I had no problem switching the fob to 4 doors and back to one again.
  20. Kzooman
    Kzooman Junior Member
    SW Michigan, USA
    Just tried on my 2010 III and it works great
