Anyway to turn off the compressor (A/C) ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mr.jerry, Dec 22, 2010.
  1. mr.jerry
    mr.jerry Junior Member
    Orange County, California
    In rainy SoCal this week, I've found that the A/C compressor is also on with the defrost/foot setting. (not mentioned anywhere in the manual). The manual does correctly note the A/C is on for the defrost mode. The compressor is on despite the A/C light not being on, and pressing the A/C button does not turn it the compressor off. Is there anyway to turn off the compressor ?
    If there isn't, I wish Toyota would update the firmware to manually turn off the compressor.
    As it stands, there is NO way to direct airflow to the windshield with the compressor off. Airflow to windshield requires compressor to be on at all times. (above freezing ambient temperatures). This is a drain on efficiency and mileage.
    My 98 Lexus ES allows defeating the A/C compressor on the defrost, and defrost/foot settings. In an efficient minded car like the Prius, this should be allowed.
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    In every vehicle I have owned in the past 20+ years, the A/C automatically comes on when one engages the DEFROST. This is deliberate in that the cooling action of the A/C removes moistures from the air stream.
    .. but then maybe you prefer a steamy windshield.
  3. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    As Teakwood says this has been common practice for a long time because if you're directing air towards the windshield the assumption is that you want it to be defrosted. Rather than a firmware update the simple solution would be to not direct the air at the windshield.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Gen II Prius has an "A/C" soft button that enables the A/C compressor. I'm surprised that the Gen III lacks this feature. Are you sure that it is missing?
    Tom
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I'm in OC, and have been turning off the AC because it's colder outside - but this brings in cold wet air, which as you see fogs up everything. I found *if* you leave it in defrost (no AC), and blow it good - it keeps the car fog free - but I then found that I really didn't care - so I pressed that AC ON button - and no longer did I have any issues with fog (air recirc, or from outside)...
  6. Former Member 68813
    3,524
    981
    US
    All my Toyota cars are like that. I would prefer more control, but more typical driver probably likes simple solutions. I do auto climate (set to 65) and only use defrost when needed. Works for me.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Uh, guys, there is a humidity sensor in the system. If the humidity is low enough the compressor will stop. If the humidity is high enough it will run. If the humidity is high enough you WANT it to run. Unless you'd rather not see where you're going! ;)
  8. Former Member 68813
    3,524
    981
    US
    How can you tell when AC works? I cannot hear a difference over engine noise.
  9. LeadingEdgeBoomer
    289
    29
    New Mexico
    Thanks, I didn't know the A/C was well-integrated into the windshield-defrosting system; I had wondered about that. It's a feature, not a bug. Any mileage hit is truly small potatoes, since no one leaves defrost on when it's not needed. #7 also noted the humidity sensor, another good thing to know.
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    Only way I've found is to monitor the air outlet temp. I've used an inexpensive indoor/outdoor thermometer (electronic) with the outside sensor dangling in a vent. Now I admit, at -18C ambient (0F), starting the cold car, it's kind of difficult to notice! ;) But once it starts to warm up you can see it cycle.
  11. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Tom,
    Maybe it's too much coquito, (Hispanic egg nog) I don't understand.
    Could you explain what this means in the Gen II?
  12. Tideland Prius
    16,125
    lol.. I have friends that leave their climate control permanently in DEFROST mode all winter. They're too lazy to switch back and forth btwn defrost and foot (they have manual climate control)
  13. Mendel Leisk
    38,646
    There's an A/C button on gen III. If you've got the ventilation Mode set to Heat/Defog, or have hit the front windshield defog button, then regardless of the A/C button being off (unlit) or on (lit), then A/C likely is running?
  14. David Beale
    5,963
    1,981
    Edmonton Alberta
    Remembering that in Prius speak "A/C" means literally conditioning of the air, that is heating or cooling, when it's on the compressor could be running. It runs when the humidity is high enough. Note that cold air is "more humid" with less water vapour in it, so you'll find it running more when it's cold. It runs to de-humidify the air.
    Also note that in the Prius having the compressor running has a much lower effect on mileage/power than in obsolete cars.
  15. Tideland Prius
    16,125
    Yes. Toyota has done that for almost 10 years now. Even in manual climate controlled cars (e.g. Yaris, Corolla, Matrix), it won't let you go into Recirc when the front defroster is set (and will switch to fresh air automatically if it was in Recirc before). The car is getting smarter.
  16. qbee42
    18,058
    3,074
    Northern Michigan
    By "soft button" I mean a virtual button on the touch screen. It's on the climate page, down on the lower left corner.
    I believe the Gen III has a physical button on the climate control section of the dash.
    Tom
  17. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    What makes me laugh is when I see cars with the windows totally fogged; I just want to lean over and switch from 'recirc' to 'vent.'
  18. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    My 2004 Prius had a A/C soft button on the HVAC page to disable the A/C
    My '07 FJ will automatically run the A/C compressor when the selector knob is in defrost or the blend setting floor/defrost.
    Since I have heated parking, that means when I pull away at -40, the A/C will run until the LP switch trips and disables the compressor. That means cold air from the defrost until the A/C trips out
    Note: an automotive A/C can NOT run in temps much below freezing without damage. Hence the LP and HP trip switches on the LP and HP lines of the A/C system
    With the FJ, there is no way to disable the A/C from running in defrost. So I consulted the service manual and found an easy solution:
    pull the clutch relay
    Problem solved. The A/C indicator on the dash blinks to indicate a fault, but all you have to do is poke the A/C button again to cancel the warning and return the idle speed to normal
  19. prius_69
    prius_69 2010 Prius White
    East Coast
    You could always disconnect the compressor eletrical wire from the compressor if it really brothers people.
    Not a good idea, since I am sure the computer will notice that and give you a error on the dash.
  20. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    They run the compressor to dry the air in defrost mode. It makes the defroster much more effective at defogging.
    The load on the compressor (power required) is not constant. It varies with compressor speed (which the Prius can control, unlike conventional systems) and largely by discharge pressure (which is very low on a cool/cold day).
    Running the compressor on low in cool weather actually takes very little power, nowhere near as much as on high during summer.
    Just let it do it's job on defrost.
