App with details on Environmental Control system?
Discussion in 'OBDII Android App' started by LEARNER, Jul 18, 2021.
  1. LEARNER
    LEARNER Junior Member
    86
    Wondering if there is an app that will give me details on the the whole AC/Heat system or do you have to hook up gauges and temp sensors first.
    I know how to do AC self-diagnostic test and I have Dr Prius and Hybrid Assistant 04 Prius
  2. ChapmanF
    15,865
    How much information you could get with such an app would depend on what the car has to give. From Gen 2 on you should be able to see the compressor rpm, and maybe the compressor watts (you can in Gen 3). Gen 3 has a pressure transducer on the high side, so you can read high-side pressure that way. Gen 2 only has a (too low)/(not too low or too high)/(too high) pressure switch. I don't know of any generation with a transducer on the low side, so you'd still need a gauge for that.
    In any generation, you should be able to see the outside air temp, cabin air temp, and evaporator temp. Gen 2 had a cabin humidity sensor but Gen 3 dropped it. I think Gen 4 has one again, combined with the windshield rain sensor (or maybe a standalone humidity sensor in that location, in trims without the rain sensor).
