Apple CarPlay on LE?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by tah, Mar 29, 2023.
  1. tah
    tah Junior Member
    Richmond, VA
    Serious question here.
    The Toyota website indicates Android Auto for the LE model but if you want to use Apple CarPlay you'll need the XLE.
    Am I reading this wrong? Or is there bad info out there.
    Makes sense to me that all the smaller displays will work with Apple or Android.
    This will make a HUGE difference in whether I'll be happy with an LE or if I need to step up.
    Thanks!
  2. TGTGUUD
    TGTGUUD Member
    70
    63
    San Francisco
    2024 Prius
    You are wrong.
  3. Hammersmith
    Hammersmith Senior Member
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You need to scroll down a bit on the screen you were reading from. I'm pretty sure what you were actually looking at was the option for the 12.3" screen that's only available on the XLE and up. If you look down further, you'll see that the LE comes with the 8" screen with all the same options as the 12.3", including wireless Apple CarPlay.
  4. Mountaindewsprite
    Mountaindewsprite New Member
    LA
    2023 Prius
    The LE has apple play I use it every day
    RojaRosie and mrlarrys like this.
