Aqua 2013 - not accelerating
Discussion in 'Prius c Technical Discussion' started by Yashvan, Nov 11, 2024.
  1. Yashvan
    Yashvan New Member
    Mauritius
    2013 Aqua
    Hi team, having an issue with an aqua 2013, was driving then engine light come on. Now it wont acclerate at all. These are the faults, change sparks plugs, still the same, it is still driving a little on hybrid battery. Engine shuddering alot when it goes to petrol but does not drive on petrol.
    see attached obd code
  2. Leadfoot J. McCoalroller
    7,847
    7,315
    Pennsylvania
    2018 Prius c
    Did you get these codes right from the get-go, or was this after changing plugs? Be aware that there are many cheap counterfeit spark plugs on the market, and some of them are bad enough to ruin the entire engine.
    With all four coils reporting a malfunction, I'd be looking for something common in the wiring- inspect for rodent damage or a disconnected/broken multipin coupler on that harness, perhaps?
    I'm certain Toyota has an official procedure for diagnosing these- might save you a lot of time to get a temporary subscription to their tech info library.
