Are 15 inches rims that bad compared to 17 inches in terms of handling?
Discussion in 'Gen 3 Prius Main Forum' started by vahrn, Dec 27, 2009.
  1. vahrn
    vahrn New Member
    66
    Parma, Italy
    I am starting to feel doubtful about picking the solar roof and therefore getting the 15 inches rims... I wasn't aware (when I ordered the car) that the Prius with 17 inches also had a better steering ratio, nor did the dealer inform me, since I asked him about the differences in handling and he said they were minimal.
    I picked the solar roof mainly for the looks and because I used to drive a convertible and thought I would have missed it. Then I thought that I could always switch to 17 inches wheels while I wouldn't have been able to retrofit the solar roof, so it seemed an obvious choice to me...
    Do you feel a noticeble difference between 15'' and 17''? Are the 15'' wheels that bad at high speeds?
    P.S.: (If I ever decide to modify my order I will also add LKA and adaptive cruise since they cost as much as the solar roof)
  2. User37
    User37 Can spell PRIUS
    83
    Italy
    I don't think you get LKA in Italy
  3. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I did not noticed any difference between the two in town driving or on a straight highway
    We also got the sun roof to let more light into the car, we still have our BMW ragtop to drive around in
    The sun roof is very noise when opened
  4. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  5. vahrn
    vahrn New Member
    66
    Parma, Italy
    I think that our configurations are different. I chose the top model which is called "Executive" which includes everything but Solar Roof; LKA, adaptive cruise, pre collision, etc; JBL. So I added Solar and JBL which cost about 1000 EUR each and skipped Safety Pack therefore foglight and LED are already included.
  6. vahrn
    vahrn New Member
    66
    Parma, Italy
    True, I just checked LKA is not available here.
  7. sdleo726
    sdleo726 New Member
    98
    San Diego
    To answer the original question, no... 15in rims are not "that bad" when compared to 17in rims, in terms of handling.
    Will you be able to drive as fast, when on a twisty mountain road? No.
    Will you have a smoother ride on rough roads? Yes.
    If you're looking for real performance, I'm sure you can find 17in wheels which weigh less than the factory 17in and 15in wheels... which will reduce your rolling weight, and increase your MPGs, but that has nothing to do with handling.
  8. web1b
    web1b Active Member
    817
    52
    Is it true that you can't add the 17" wheels later to a Prius that didn't have it from the factory because the package V is built differently and the 17"s won't fit on other packages?
    I wish there was a middle 16" option with less expensive tires and wheels that the 17s, but looked better than the 15s.
  9. skamar
    skamar Junior Member
    16
    Greece
    I have ordered mine exclusive with solar pack because of the hat weather here in Greece. Till now I have only have driven the exclusive without the solar pack but I don’t think that they would have too much difference.
  10. austingreen
    austingreen Senior Member
    13,572
    4,109
    Austin, TX, USA
    You should be fine to upgrade wheels and tires to 16 or 17s. In the us many have put Toyota sized 215/45R17 tires on lighter weight wheels than toyota. I put on 205/50R17s and you could use 205/55R16s on the car. Others have even put 18 inch tires.
    Toyota has different options in different markets. In the US the package with 17" tires also includes a better steering motor, different turn ratio, different programming for power steering, as well as the led headlights and fog lamps. In Europe I think you have the different motor and programming. You should be fine with this and upgraded wheels. If the diameter of your tires change the spedometer will have an error, but I chose tires that were very close. Otherwise live with it, or pay for the dealer to change the computer to the new size.
  11. Fstr911
    Fstr911 Member
    235
    55
    Re: Will you be able to drive as fast, when on a twisty mountain road? No.
    No disrespect intended but ….LOL
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Like other's have stated, it all depends on what you want out of this car. If you want to sling around corners and feel like you are "in touch with the road" then the 17's are a MUCH better option. You will lose MPG with the 17s due to added tire friction and possibly weight. The ride will also tend to be more bumpy and some may consider it harsh.
    I regulary swap back and forth between 17s and 15s so I'm pretty well versed on how the wheel/tire size affects ride and handling. I'm one who loves to corner carve in a Prius. ;)
  13. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    if the op is referring to "stock 15" wheels and tires, then yeah the trade off is that the stock narrow tires offer lower rolling resistance, which means less contact with the road. 17"s tend to be wider, offering the performance in handling that many of us experience.
    a more appropriate question for many here is:
    (most cost friendly)
    what's the max width performance tire size for a stock 15" wheel?
    (more costly)
    where can i find new wheels/tires at a pricepoint lower than what toyota offers?
    the 2nd question has all kinds of answers....do not know about the first, but im curious.
  14. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  15. vahrn
    vahrn New Member
    66
    Parma, Italy
    Thank you for the replies.
    I'll stick with the solar roof and the 15in wheels. I have asked around about the different steering ratios in our models but nobody has ever heard of them. Maybe Euro models are all the same, also because the equivalent of the model V is called Executive here and can be ordered with the solar roof.
    Whatever benefit bigger wheels might provide in terms of better handling in fast curves I prefer to avoid them. I was just concerned about regular, calm driving on the highway. I used to drive a Boxster and I would make silly comparisons, which would make me regret about switching to the Prius. I took this (hard) decision because I was (am) a reckless driver and spent more money in paying speeding tickets than in gasoline and tyres which were already big expenses since I averaged 12.500 miles per year and also because I believe that there are more important things in life than driving like a madman in public streets wasting gas.
  16. sdleo726
    sdleo726 New Member
    98
    San Diego
    YEAH! what he said :fish:
  17. Rhino
    Rhino New Member
    460
    U.S.A.
    Funny. I love the Prius with its good and bad points but I'll be embarrassed if my friends saw me handling it on a twisty road. My Prius is in the shop (hit and run). I got a Sonata loaner car from the insurance company. These $25/day rental cars are so much faster.
  18. Fstr911
    Fstr911 Member
    235
    55
    I didn't mean to be too critical but- making blanket statement that you'll “not be able to drive as fast on a twisty mountain road” is just not a simple "no". And yes I know that Florida is flat (what are these things called mountains?).
    Unsprung weight, corner balance of the car, weight of the driver, tire type, tire pressure, driver capability, temperature, road/surface conditions, HP and a lot of other stuff play a role here.
    After all those 17 inch wheels look pretty good. And in the real world I suspect
    99.5 % of the Prius drivers would never notice a difference. So IMHO…put those 17 inch wheels on…smile
  19. Fstr911
    Fstr911 Member
    235
    55
    RE: I got a Sonata loaner car from the insurance company. These $25/day rental cars are so much faster
    Comment: It has to be the 16 inch wheels right? I mean nothing else could affect it...smile
  20. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
