are all the gen 4's ow-16 oil?
Discussion in 'Gen 4 Prius Main Forum' started by MikeV, Aug 20, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    just bought a 2021 l eco and realized the oil is ow-16 as opposed to my 2010 which is ow-20.
    49,844
    yes
    Pulse07 likes this.
  3. MikeV
    MikeV Junior Member
    95
    philadelphia
    can you buy that in 5 qt containers or just by the qt.
  4. JC91006
    16,501
    8,413
    0w-16 has been around for many years, you can get that in the 5 quart jug. But if you can't find 0w16, you can use the 0w20 without much issue. They are very similar
  5. Doug McC
    Doug McC Senior Member
    1,011
    381
    Midwest
    2022 Prius
    0w-16 is easily available at your Toyota dealership or even some Walmarts. Do yourself a favor and check the owners manual for your vehicle concerning using any other oil. For example, for my’22 if you use 0W-20, you have to change it within 6months/5Kmiles back to 0W-16. 0W-16 is the only oil that meets 6B requirements for a ‘22 so check your manual for yourself to see if it’s required for your ‘21 (oil that meets 6B requirements, because 0W-16 is the only oil that meets that spec).
    Failure to use the correct oil grade/specs can and will void your warranty regardless of what Prius Chat “experts”, wannabe “engineers” say. Additionally, there actually is a difference between the 0W-20 and the 0W-16 in that the 0W-20 meets 6A specifications and 0W-16 meets 6B specifications (per AIP and PQIA (the REAL engineers and experts when it comes to lubricants)).
    Pulse07 and MikeV like this.
  6. Doug McC
    1,011
    381
    Midwest
    2022 Prius
    FWIW: Penzoil makes a 0W-16, as does Mobile 1, (which also makes Toyota’s oil, but to Toyota’s specifications (ie: higher levels of additives, per tests that have been published on this site and others)).
  7. Doug McC
    1,011
    381
    Midwest
    2022 Prius
    BTW, to answer the question of the title of your post: No, not ALL Gen 4’s require 0W-16, just the later years.
    MikeV likes this.
  8. MikeV
    MikeV Junior Member
    95
    philadelphia
    thank you will stick with 16
    Doug McC likes this.
