Are center caps necessary? Form, function or both?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by FirstAndTen, Aug 3, 2011.
  1. FirstAndTen
    FirstAndTen New Member
    Minneapolis, MN
    Hi! I have been a lurker for awhile. I have a 2010 Winter Grey II. Took the "what I think are" ugly hub caps off awhile ago, but haven't addressed the center caps. I have been looking for an answer to this, but can't find one.
    Are the center caps necessary? My friend who used to work at Ford saw my missing center caps and said I should take care of that so they don't "dry out"?
    Is this true? 99% of the threads on center caps seem to focus on the "look", not the function.
    In the long run, are my wheels worse off with no center caps?
    Thanks
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Purely form.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There is nut in there to remove the front hub that I like to keep clean for future repairs (front wheel bearings). But, yes mostly form.
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I agree, though keeping crud away from the front wheel bearings is a good motivation to put something in the open holes beyond "looks".
  5. Mr. Prius
    Mr. Prius Junior Member
    82
    24
    Do they make Toyota OEM caps and/or do you recommend a certain brand?
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes they do, but kind of spendy (nearly $50). There is also a thread on here about $3 knockouts that will work too (no emblem).
  7. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Unless you go off-roading, how do they stay any cleaner (or "dry out" less) behind the hubcap than with it off?
  8. noweyout
    noweyout Trying to get used to it
    24
    SoCal - SGV
    Look on ebay for the lazy-man's solution to center caps. If you don't want to go looking and painting home depot center caps, those ones made overseas are great!
  9. bnaccs
    bnaccs bnaccs
    191
    Colorado
    $50.00 for one from Toyota? What do ask for when ordering them at a dealership? Any pics of these $50 caps? Also, does the Prius Chat Store sell any?
  10. macmaster05
    macmaster05 Senor Member
    4,050
    727
  11. Mr. Prius
    82
    24
    Just bought a set of 4 for $9.88 w free shipping on eBay
  12. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The nice thing about the knockoff version is that they are removable via a tiny slot that is present.
    I presently have my hub caps on and the center caps are not compatible with them on simultaneously.
    I cant' speak for the genuine ones.
  13. Mr. Prius
    82
    24
    Do you gently tap them in w a hammer?
  14. macmaster05
    4,050
    727
    It's the same way. In fact the genuine caps protrude more than the eBay caps.
    As far as installing them, you could use a mallet I suppose. I just used my hand though. Lined up a clip on one side, and pushed hard to snap in the other 3 clips It's a tight fit so you have to give it a little force.
    The caps really finish the look though. Nobody can tell that they're not OEM. Mr. Prius you will be pleased.
  15. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I don't know if you mean the center caps or the hub caps w/ the center caps on.
    I inserted the center caps by hand, I could have tapped it with my fist, but it seemed to go in very easily. But then it was very snug and I was confident it would not fall out. It's not possible to take it out without using the slot.
    As for the hub caps, tapping them with a hammer will keep the hub cap on with the center caps installed, but you will notice that it is bulged out in the center, and the hub cap is not very secure. In other words, the center caps interfere no matter how well you try to install the hub caps.
    The only thing you can do is shave the circular ring on the inside of the hub cap, which is what hits the center cap. But I did not want to modify my hub caps to conform it to the center caps.
    I wanted to put my hub caps back on. I found the center caps were very secure, and I couldn't take it out by hand. But there is a small slot where you can insert a thin tool to pry it out, and that was easy to do.
  16. macmaster05
    4,050
    727
    +1. That's why I waited so long, over a year, to get center caps. I couldn't decide whether I wanted my hubcaps on or permanently off. It took a long time for the bare alloys to grow on me. I'm never going back to the hubcaps and that fate is sealed with my new center caps. :D
  17. Mr. Prius
    82
    24
    Attach a picture or point me to where u have posted one
  18. FirstAndTen
    Minneapolis, MN
    Thanks for the link! To confirm, I have a Gen III, 2010 II. The year range worries me... 2004-2010??? I thought the generations were clustered as such: 2003-2009 and 2010-present. Only reason I ask is that I read the center cap size is different for Gen II and Gen III.
    Confused. Your link says 2010, but I am trigger shy.
  19. macmaster05
    4,050
    727
    My pictures and summary is on page 10 of that thread. I took 3 pictures. You can't miss it. They may take a while to load so you can try refreshing your page.
    Good question. 94+ people have bought this item recently. I would think at least a handful of those buyers owned 2010+, and if it hadn't fit they might come back with something negative to say - but it doesn't look like that. PriusChat member Revhigh owns a 2010 and just ordered the same caps shortly after me. He should have them by now. You could ask him.
    For an even more definitive answer, read the 2nd post in this thread:
    http://priuschat.com/forums/gen-ii-...leshooting/75295-center-cap-size-touring.html
    From what I gathered, the 2010 caps are the same, 2.25".
  20. Tideland Prius
    16,066
    I doubt it. I'm using the same centre caps as the ones on my 2005 Prius (the domed ones). You can use the flatter ones (I don't have the part number handy). Those are found on the 2009+ Corolla, 2007+ Camry and so forth.
