Are modules tested 8.0v at 3.5ah good enough for a full pack replacement on an older car?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, Oct 11, 2025 at 12:48 PM.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    Need to do a rebuild on a 2010 Camry. The seller warns that these will not work for a full battery rebuild but I don't need it to work at full capacity, just good enough.
  2. BiomedO1
    BiomedO1 Senior Member
    3,213
    1,704
    SacTown, Ca
    IMHO; Salesmen can say anything on fleabay - You need to test and verify!!!. I can get an 8-VDC reading, surface charge right after disconnecting the charger. It needs to be run through a battery tester and see how it handles a current load. Current load test will reveal how it's going to help or hinder your traction pack operations.
