Are my rotors as bad as the dealership says?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bigjt_2, Sep 4, 2017.
  1. bigjt_2
    bigjt_2 Junior Member
    Indianapolis, IN
    On my last service appointment at my dealership, they told me my front rotors are "extremely rusted." Then they suggested I completely replace the brakes AND rotors for about $500. I asked if they could just replace rotors and "I wouldn't recommend it." I did a lot of researching on here and realized a lot of people had come up with this issue, but then it turned out to not be an issue. Either the person who told them to replace rotors didn't know what they were doing (the iron rotors on Priuses are always rusting, but the brackes scrape it off) or were just trying to make a quick buck.
    I looked at and felt the rotors through the tires and they looked fine to me. The edges are very rusted, but the places where the brakes make contact are smooth and mostly shiny. There are small streaks of rust where the brake pads usually make contact but it's not like the whole surface is covered with rust. I have not tried the trick yet where I get up to 55mph+, switch to neutral, then brake to scrape off rust.
    I just wanted to post pictures here to ask your folks' opinions, because this dealership has tried to milk me before. Do my rotors look like they need replaced to you? Or is this another of those cases I mentioned above? I was trying to avoid taking the wheels off. But if I certainly can if anyone wants clearer pictures of the rotors. IMG_20170829_174444919.jpg IMG_20170829_174520831.jpg IMG_20170829_174528201.jpg
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,854
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, your dealer is trying to fund his next vacation. The only corrosion that should concern you are the rotor surfaces (cleaned by periodically switching to neutral at ~ 30 MPH and lightly applying the brakes. Repeat until the brakes operate quietly and smoothly) and the caliper slide pins (if they stick, the inner and outer pads will wear unevenly. Get them lubricated once every few years).
    JeffD
  3. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    Get 2nd opinion. The brakes can be measured. New is 10MM...Any less than 5mm should prob be replaced.
    $500 is about $200 too high imo.
    The rotors can also be measured.
    49,516
    they look like brand new! how many miles on them?
    if original, it's worth having a professional look and measure.
  5. ChapmanF
    15,697
    That would be making far too much of a production of it. All it takes is a couple normal stops on a residential street, say 20 to 30 mph, just like your normal approach to a stop sign, but in neutral. Not something your passenger would ever notice unless watching you shift.
    No big production needed. It just becomes second nature, any time you drive the Prius away from a place it's been damp-parked, if you notice a bit of scraping noise or extra grabbiness from the brakes, you just do that at the next couple stop signs without really thinking about it, all fixed.
    The rotor pictures look fine to me, though the real criteria for replacement are loss of thickness or warpage, neither of which I can judge from a pic.
    -Chap
  6. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    A common trick is to sell rotors with a brake change since they get a markup for the rotors + can double bill for the labor. Basically it take no more labor add on installing new rotors but they bill you as if you were only installing rotors.
  7. bigjt_2
    Indianapolis, IN
    Thank you all for your kind guidance and assistance. Happy Labor Day!
    Raytheeagle and bisco like this.
  8. Mendel Leisk
    38,750
    Anybody got the second gen specs. These are third gen specs, might be similar
    New/min thickness: 25.0/22.0 (mm)
    Max runout: 0.05 (mm)
    DIY check of both values is failr easy, you just need to remove a wheel, and have a dial indicator (with magnetic base) and a 0-25 mm micrometer.
    Still, I suspect nothing is wrong with the rotors, per the other responders.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Tell them your opinion of them just went down the drain. Tell them you'd like to do business with someone that is not a con artist, then find another dealer. The new rotors would look like that in a week anyway. Come to think of it, you'd could probably find a new car on their lot that looks just like that or worse if it sat for more than a day or 2.
    Montgomery, MilkyWay and bisco like this.
  10. Mendel Leisk
    38,750
    Before you completely burn your bridges, check 'em yourself, or get an independent professional check. They could, for example, look great but be down to minimum thickness.
    Who knows. As long you're not empowered, don't "knowledge up" yourself, you're at their mercy.
  11. bigjt_2
    Indianapolis, IN
    Thanks for you helpful info in the above post, too. I'll see about getting that inspection done.
