Are people really getting 40+ MPG in Gen 2?
Discussion in 'Gen 2 Prius Fuel Economy' started by timmyjane, Apr 12, 2017.
  1. timmyjane
    timmyjane Junior Member
    87
    SC
    I pretty much only get around 34MPG. I drive a good bit. Lots of highway and side roads. Not much stop an go but some. I talked with a 2014 owner and his display is showing something like 46 MPG over 3-4K miles. Ive been tracking my fuel purchases and MPG since last August and have only gotten 40 on one tank. It seems that the MPG has been dropping lately as I have only averaged 33 over the 4 tanks in March. November and December was better.
    I started looking around this forum and it appears some folks are getting 40+ in their Gen 2. It this unique or the norm? I have 230k on the car. Tires are new last month. 12v should be good. Last I checked the main batt was good too but I sort of want to check it out now. Yes I have read the how to improve MPG post and I do try to glade and generally be aware of my current MPG.
    What is everyone else realistically getting?
    52,357
    yep. you have a lot of issues, and to be truthful, idk if you will want to spend what it takes to get a 230k car back to 40+ mpg.
    do the posts of 40+ mpg you are seeing come from people with almost a quarter million miles on their car?
    things wear, get dirty and etc.
    Light and Spaysship24 like this.
  3. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Yes. Looking at fuelly.com and fueleconomy.gov the Gen II Prii still being reported are averaging in the neighborhood of 43 mpg overall. Ours is right there, too.
    Some people have experienced emergency brakes that don't release all the way. It would be good to check the regular brakes, too. That could easily account for your low mpg.
    Data Daedalus likes this.
    52,357
    or perhaps extra weight in the vehicle?
  5. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    At my daily way to the office and back to my home I need 5.0 l/100 km with my Gen2 (118000 km, 73300 miles). That's 47 mpg.
    At trips with more flat terrain I need less fuel.
    When driving longer distances at autobahn with 170 km/h (~106 mph) , I need round about 6.5 l/100 km. That's 36 mpg.
    SM-G900F ?
    landspeed likes this.
  6. bisco
    52,357
    does your car have a quarter million miles on it?
    Rich Obermayer, Valiant V and Light like this.
  7. MickyMatter
    260
    168
    Germany
  8. bisco
    52,357
    is this based on a new prius, or one that needs a lot of tending to?
    Valiant V likes this.
  9. MickyMatter
    260
    168
    Germany
    No. As you can read above only about 73000 miles.
    SM-G900F ?
  10. bisco
    52,357
    i wonder if mpg's decline with wear and tear.
  11. MickyMatter
    260
    168
    Germany
    That's possible. But at first I would check the tire pressure and the engine air filter.
    Sorry for asking, but you're using the right fuel? In Germany we use 95 RON (that's 90 AKI). A fuel with a smaller value decreases the mpg. Next put not necessary weight out of the car. Then check your brakes too. Mine and many other disk brakes may stick in brake position and don't release properly. Cleaning their guidance may be helpful... (European gen2 has rear disks too, and my rear left pads were fully fixed by rust and dust)
    SM-G900F ?
  12. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I was still averaging in the low 50's when I sold my '04 last month, but it didn't have 230,000 miles on it, only 229,000 :)
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I didn't see mention of how long you've had the car and if it's always been like that since you got it. Nor do we know anything about the service history.
    It may be as simple as a tune up (throttle body cleaning, new plugs & pcv valve, etc.), and replacing air filters. Don't forget the cabin air filter. It can affect mileage, too. A grid charger to do a charge/discharge re-balance of the HV battery can also help. When I traded in my '05 with 150,000 on it, I was getting 47-49 mpg with an occasional 51 mpg.
    Even with doing that, I would not expect optimal fuel economy on any vehicle with that many miles. But 33 seems low even for a quarter million miles.
  14. timmyjane
    87
    SC
    Thanks for all the feedback. I have had the car for about 2 years. I really only started tracking the actual fuel economy about a year ago. It seems to be on a decline in economy.
    The spark plugs and filters are well maintained. Oil is kept up as well. Tires are new and pressure is good. I'll check on the brakes. HV was rebuilt last year and last I looked all cells were where they were supposed to be. That was about a year ago as well so it may be time to break out the computer again.
    It is interesting that something is not quite right. I always assumed the MPGs were where they were supposed to be. Now I feel like I need to know what the problem is.
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    What brand and model tires do you have on it? Are they low rolling resistance tires. What pressure are they inflated to?
    Today I drove a combination of highway (at 50 to 55mph) plus a couple miles of stop and go in electric mode, and got 58mpg for 2i miles.
    But generally 42-55 mpg.
    2005 base model Prius
    170,000 miles.
    Eric.B, Sara J., ClemsonSteve and 2 others like this.
  16. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Please let us know what tyres you have fitted and what pressures they're set at.
    Who exactly services your Prius? Is it serviced and maintained per schedule by a Toyota Dealer (or at least a dealer with genuine technical knowledge about servicing Prii)?.
    What type of spark plugs were last fitted for example, and when? Any ordinary spark plug won't do.
    Other recommendations by other forum members are pretty much spot on; tyre pressures, servicing of rear brakes and throttle body, is the vehicle heavily loaded? Even driving style does make a difference - do you ever employ hypermiling techniques?
    What are your A/C settings? Do you employ the use of heating a lot? All these things matter too.
    I hope we can track down why your mpg is low, but it might well be one of the above.
    iPhone ?
    Kenny boy and srellim234 like this.
  17. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Do you share the car with anyone? If so, it could be the combined driving styles that is bringing down the mpg. My wife & I both drive our Prius and she usually brings down the mpg due to her driving style. When I drive the car, I bring the mpg back up.
    If you are the only one driving it, I would check the things other members have mentioned. Throttle body and mass airflow sensor may need cleaning. PCV valve may need to be replaced. Have you gotten a brake flush yet? Transaxle fluid drain and refill? What's the temperature like when you drive?
  18. Moving Right Along
    Moving Right Along Senior Member
    731
    588
    The range on Fuelly is roughly 38-56 MPG, with most people in the 40s. If yours is 36 MPG average, there's probably something causing it to be lower than it should. In addition to the mechanical things you can check that were stated by other posters, driving exclusively short distances (say under 5 minutes) will give you lower miles per gallon, and driving up and down hills can wear out your battery faster. Also driving at autobahn speeds (as mentioned earlier) would lower your fuel efficiency as well.
    srellim234 likes this.
  19. bisco
    52,357
    do you drive her hard, and put her up wet?
  20. fuzzy1
    10,602
    jerrymildred likes this.
