Are some models more prone to catalytic converter theft?
Discussion in 'Newbie Forum' started by screed, Sep 28, 2021.
  1. screed
    screed New Member
    new york
    2015 Prius c
    hi - I have a 2015 Prius-C and I'm wondering if some models or years are more prone to catalytic converter theft than others?
    The reason I'm asking is because I've looked at a couple of theft "preventative devices" but I'm not seeing the "C" listed.
    thx
    51,155
    gen 2 has the most precious metals, but all are susceptible to some degree.
    it's a matter of risk tolerance, i'd like to think you have nothing to worry about, but i can't guarantee it.
    screed likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Expensive replacement if an idiot saws through the engine preheater located behind the second catalytic converter. Prius c exhaust.jpg
    screed likes this.
  4. Flowbee
    Flowbee Junior Member
    Seattle
    New Prius owner here. I'll piggy back on this thread instead of making another so I get flamed less for reposting.
    I have a gen 2 and haven't had the tools to get under it and look at everything yet but..
    1. I've thought about a cat plate though the price of some are almost as much as replacing a stolen with a new aftermarket. Then I saw this guy's video and thought it was kind of clever
    NAPA sells exhaust U clamps for only $1.50 each. How many would I realistically need to cover the vulnerable cut areas? My Prius has 2 cats front and rear? Are thieves mainly cutting off the rear and not going for the one bolted up front? Or are they taking both?
    2. I bought a vibration alarm
    What's a good mounting spot for this where I could mount and remove by reaching under the car? Do thieves usually jack up the driver or passenger side? Maybe it doesn't matter if this is sensitive enough.
    FireLawdZuko and screed like this.
  5. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    screed likes this.
  6. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    as @bisco mentioned, all vehicles have some risk
    But that being said, never heard of a "c" cat being stolen.....have not researched that,
    but being that I own a "c" I have thought about it.
    I am not worried at all....esp in my area....which does have cat theft.
    I think Gen 2 has highest risk overall for a Prius.
    Gen 1 and 3 still have seen posts on PC forum
    But "c" again, never heard of it happening. I am sure it has been done tho.
    Hope this helps.
    screed likes this.
  7. screed
    screed New Member
    new york
    2015 Prius c
    Is the alarm a stand-alone device and self-powered? There's so much vibration, is it only activated when the car is off? thx
  8. Krall
    Krall Member
    125
    37
    NY
    Are the high mileage ones that are shot worth stealing?
  9. ABQBob
    ABQBob New Member
    Albuquerque NM
  10. ABQBob
    ABQBob New Member
    Albuquerque NM
    I have a 2012 Prius C and just had my catalytic converter stolen a few days ago while parked at a commuter rail station for 8 hours. They damaged the coolant lines as well. Found saw blade on the leaked puddle of fluids. $3600 to fix. Luckily insurance will cover ( with $500 deductible). Trying to figure out what to do to keep this from happening again. I am worried it will happen again.
  11. vvillovv
    4,318
    1,499
    NY
  12. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    Yep, the ones parked where thieves feel safe.
