Are there after-market keyless entry FOBs available?
Discussion in 'Gen 2 Prius Audio and Electronics' started by PriusVancouver, Nov 27, 2014.
  1. PriusVancouver
    PriusVancouver Junior Member
    We lost one of the two key fobs. Over $200 to replace from dealer. Are there universal or after-market options for less? Thanks! Adrian.
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    It might depend somewhat on year and model but the likely answer is YES.
    Call around to a few locksmiths in your area. They usually have (or can get) them for about half the dealers price.
    49,371
    actually, 200 is very reasonable for a dealer. there are many threads here you can research. some have had success, and others haven't.
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    Yo Adrian; what kind of car/fob do you have? Where are you located?
    Some fobs can be self programed and purchased on Ebay. Others require someone with appropriate software to do the programming.
    If you provide a little more information we can provide better answers.
  5. bisco
    49,371
    i wonder what happens in a week, vacation?(n)
  6. Enio Cordoba
    Enio Cordoba New Member
    South Pasadena, Ca
    Hello Vancouver
    Absolutely! Caveat if you have the Smart Entry feature you need to research the replacements with the correct SILVER toyota logo on the back. The others are not programmable. The correct ones are available on Amazon for $118 . THEN google search "Chicken Dance for Prius". It is the programming procedure that you can do on your own without a locksmith. Very easy and takes 30 minutes.
  7. Richie Conway
    Richie Conway Junior Member
    I just bought one on ebay for 104, same dealership that sells them for 115 on Amazon and programmed it myself. I went to home depot and they cut the key for free! It works excellent!
  8. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    Another option is to buy the ovni key from ovnisf.com. It's $35, I think. You do the chicken dance and it works. Functions limited to starting and getting into your car though. No keyless entry. But a lot cheaper than a fob. We did one as a spare.
    SFO likes this.
  9. Bev1111
    Bev1111 New Member
    Arizona
    I just bought a 2006 Prius 2 days ago and realized I cant lock the car. I was able to take the key out of the fob, but the back cover is stuck and I cannot access the battery. Looking on the PDF manual I see that might be the problem and it makes sense, but am literally stuck. Also the actual key locks on the doors are covered and I cannot insert the key! HELP
  10. 3prongpaul
    954
    720
    After you remove the key the back cover comes off, sometimes they are stuck pretty good and require strong fingers to slide it off if there is years of crud. You need to slide the switch while you slide off the cover see
    There is only one mechanical lock on the car, on the drivers door. The slide out key from the Fob should unlock / lock the drivers door. If it doesn't get a key made since there will be no easy way to unlock/access the car if the 12V battery dies.
    SFO and bisco like this.
  11. bisco
    49,371
    lubricate the lock mechanism with graphite before trying the key, and use a pair of pliers for leverage, but don't twist too hard.
    SFO likes this.
