Are there any cases of someone successfully turbocharging a 4th gen Prius?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by GavinHogberg, Sep 29, 2022.
  1. GavinHogberg
    GavinHogberg Junior Member
    Illinois, USA
    2021 Prius
    I want to find a way to turbo my 2021, but I haven't heard any cases of someone successfully turbocharging a 4th gen
    2020XLEAWD likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I doubt that it would be achievable - economically. For a start, you'd void the warranty on both the engine and, I suspect the Hybrid drive-train. And - I suspect the computers managing both the engine and the Hybrid system would need massive overhaul - or they'd get utterly confused.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,049
    532
    Tucson, AZ
    2021 Prius
    The Atkinson cycle ICE in the Prius actually releases some of the cylinder air/fuel charge back into the intake manifold on the compression stroke, so that won't work like it should if the intake manifold is pressurized. Plus, the ICE will periodically turn off with the vehicle continuing to move under full electric if the engine is warmed up to operating temperature, the hybrid battery has a suitable state of charge, and your foot is light on the accelerator. This would likely cause a very undesirable turbo lag when the ICE turns back on. As to the computer and ECU's, they are all designed for the present drivetrain configuration and I would imagine the programming is very proprietary.
    alanclarkeau and douglasjre like this.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    A gentleman (I think the term is hoon) in Australia both supercharged, then turbocharged a gen 0 Prius. To his surprise, it charged the battery quicker. You may need to consider what you would do with more power if the software is not inclined to travel faster.
    alanclarkeau likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,089
    Columbia, SC
