Are these dealer suggested services valid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by liskipper, Aug 19, 2019.
  1. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    My 2013 model 3 has 108K miles. Dealer says I need:
    1) Flush/replace inverter coolant. $180
    2) Flush/replace engine coolant $180
    3) Clean hybrid battery fan $290
    4) Replace spark plugs $250
    5) Flush/replace trans fluid $200
    Sounds like BS. Any comments?
  2. schmuber
    schmuber Member
    115
    85
    Georgia
    Can I be your dealer for a day?
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I would do the recommended 100k services from your maintenance manual, but not at that dealer. Those prices are way high. As an example, the transmission doesn't get a flush, it gets a drain and fill. That should cost $80-$100 including fluid. My dealer quoted me $289, then $189, then $119 for this service in the space of 45 seconds.
    Find a good independent shop and have them do the 100k service at much lower cost. Or DIY for a lot less than that.
    #3 jb in NE, Aug 20, 2019
    Pseudonymm likes this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    First, here is your maintenance guide:
    https://www.toyota.com/t3Portal/document/omms-s/T-MMS-13Prius/pdf/2013_Toyota_Prius_WMG.pdf
    Second, I am assuming you have never had any of this done. Here is the timing:
    1) page 44 at 100,000 miles, checks out.
    2) page 44 at 100,000 miles, checks out.
    3) never in the schedule, it will depend on how much hair/dust/smog you go through. If you own dogs in NY, I believe it.
    4) The manual says 120,000 miles unless it is a CARB state, then 150,000 miles, I would do it at 120,000, unless there is a code they can show you.
    5) This is never in the manual, but every 100,000 miles is good advice.
    Now, I live in rural MS, not NYC, so your prices are about double what I pay. (5 has been $90- $110 for me) I would get a second opinion.
    Hybrid Auto Tech
    1204 44th Ave, Long Island City, NY 11101
    (718) 482-1414
    seems to have mixed reviews.
    Mendel Leisk and Pluggo like this.
  5. Matthew Lindsay
    Matthew Lindsay New Member
    Harrisburg, Pennsylvania
    oh lord if I could get that kind of money for doing those things, i'd be a millionaire.
  6. Mendel Leisk
    41,901
    Good advice above, especially @JimboPalmer's breakdown. You need to open the Warranty and Maintenance Booklet, check in advance what happens and when, and note it's miles or months, whichever comes first.
    And yeah, a lot of the dealer's quotes are absurdly high, in particular the transaxle fluid drain-and-fill. As @jb in NE says, $80~100 is reasonable. It's comparable to an oil change in complexity/time.
    I would add brake fluid change, sometime soon, and that should not be more than $100~125.
    Here's the US third gen schedule; I converted to graph format. Note, there is no transaxle fluid change, just inspection, but that's Toyota USA for you. Regardless, I would consider doing a change, ASAP. Then you can stretch it:
