Are these repairs necessary?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nate Byrne, Dec 22, 2014.
  1. Nate Byrne
    Nate Byrne New Member
    27
    Longmeadow, MA
    Hi guys, I recently ran over a dead deer. Yeah. The car thankfully runs fine, and I had Toyota check it out. They told me everything is great except the deer dented the fuel tank pretty bad and might have pushed it up into the floor plan. They told me to take it to an auto-body shop and work my insurance.
    My question is... is it necessary I fix this if there are no leaks? I'm a college student and I can't afford to do unnecessary body work to the undercarriage of my car, so I want to be sure.
    I spoke to my insurance, they will cover anything over $500. How much could you GUESS this would cost? Thanks for any feedback.
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Don't guess. Take the car to a shop & ask. It'll be a lot more than $500.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    The thing is with these Gen II Pri the fuel tank is more sophisticated than most to limit emissions during refueling. Your tank may not be leaking externally, however it might be leaking internally via the bladder. No real way to tell unfortunately until you throw an evap code I suppose. If it were me I'd find a way for your insurance company to replace the fuel tank under your collision/comprehensive coverage.
    49,842
    hate to give you bad advice, but if there are no codes, it might be fine. i guess, 'dented it pretty bad and pushed it up into the floorboards' is in the eye of the beholder. have them put it on a lift and show you. sounds like a couple thousand bucks, no pun intended.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    749
    Delaware
    better to get it resolved now than wait until it causes a problem and its too late to get insurance to cover it. a normal fuel tank can be popped back into shape with compressed air, but since Toyota decided (stupidly) to put that worthless bladder inside the tank, you got to get it fixed asap.
  6. ETC(SS)
    6,589
    Hmmmm.
    This is a wobbler.
    I'd be tempted to drive it for a bit since we're dealing with an 8-year-old college car being driven by a (presumptively) unmarried younger driver.
    You're going to have to balance the insurance payout against the rate increases and the true value of your now previously-wrecked car.
    There's a lot of moving parts there, and you're going to have to do the coin-toss yourself.
    What's your driving record look like?
    Do you owe anything on the car?
    What's the budget say about the initial $500 outlay for the repair?
    Is the car safe to drive?
    I would certainly take it to a good mechanic (NOT Toyota and NOT a body shop initially) and pay them an hour's rate for a thorough inspection with an eye for determining what is astheticlly and mechanically prudent for getting you through college and into the next car.
    I wouldn't worry too much about the former.
    Since you're driving a wrecked car, it''s going to take a significant ding in value (pun almost unintended) whether you fix it or not.
    Good Luck!
