Are Tires Nitrogen-Filled?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by meehow09, Mar 14, 2012.
  1. meehow09
    meehow09 New Member
    42
    Chicago
    I just noticed today that my Habanero Prius C 3 has green caps on all the tires where you would refill them. My wheels are the 15 inch steel wheels.
    Does anyone else have this?
    Also, does this mean that they are nitrogen-filled?
    No one at the dealership or the manual says that they are nitrogen-filled, so I don't know if they are. My past car had green caps and it was because they had nitrogen.
  2. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I guarantee that your tires contain at least 78% nitrogen!
    kevtan, frodoz737, Stevie and 5 others like this.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Green caps are standard for "nitronized" tires. It's a gimmick. Fill them as you would any normal tire.
    Tom
  4. actiondonkey
    actiondonkey Member
    91
    30
    My understanding is the 'nitrogen filled tires' only help those who do not pay attention to maintain proper tire inflation. I think the idea is from the nitrogen molecule being fairly large so it exits the tire at a rate slower than the air you'd usually pump into your tires. Like qbee42 said, it's a gimmick. I just cannot see how a little nitrogen can lighten the wheels/tires enough to see any appreciable difference.
  5. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Green caps are used to signify nitrogen but I wouldn't pay to have them filled, ambient air is usually 78% nitrogen
  6. qbee42
    18,058
    3,081
    Northern Michigan
    That's one of the claims, but it's not true. The diffusion rate of nitrogen is very close to that of air.
    Tom
    2 people like this.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    In CR's nitrogen test, starting with 30 psi, over a 1 year period the N2 tires lost 2.2, while air-filled lost 3.5 psi. So the difference is a little over 0.1 psi per month
    In most locations you have to adjust inflation for seasonal variation so it has minimal value. If you really care about mileage you check more frequently.
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I know of a bridge made entirely out of Monster Cable........
    Ashlem, w2kpugsly and F8L like this.
  9. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Nitrogen filled tires are not primarily for either of those purposes (lightening or slowing deflation).
    Nitrogen is a cheap inert gas. Replacing the oxygen content of air in a wheel & tire assembly with nitrogen prevents slow oxidation (corrosion & rot) of the elements and compounds used in wheel and tire construction. Nitrogen filled tires being oxygen free, also will not support fire (rapid oxidation) in the event of a collision or a tire failure.
    The benefits of nitrogen filled tires on automobiles are minimal due to the speeds and pressures involved. In a high speed jumbo jet weighing 350 tons, touching down at 200 MPH with its wheels at zero rpm, and tires inflated to 275psi mounted on magnesium wheels, directly below 300,000 pounds of jet fuel - nitrogen inflation is very important.
    MrBill
    :eek:
    Ashlem, frodoz737 and nerfer like this.
  10. qbee42
    18,058
    3,081
    Northern Michigan
    I wouldn't read much into that small of a variation, given CR's typical testing methods. It's probably not statistically significant.
    Tom
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Honestly now. How many tires have rotted out on you because they were not filled with 100% nitrogen. Furthermore, how many tires (inside) have rotted out on you period? Then I would like to know how many have exploded into ball of fire? :D
  12. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    My wheels regular rot out ;)
    In fairness he was pointing out I think the theoretical benefits, or those in different applications than a passenger car, not affirming the belief that it's a worthwhile practice.
    The joke above about monster cable is very apropos.
  13. pmike
    pmike Member
    237
    81
    Central Florida
    Nitrogen filled tires are total BS and I am telling you this not because I love you or care about you but because I HATE bs scammer/marketers. Check your tire pressure every 3 months, if you give an F or when your car notifies you they are under-inflated. I check my about every 3 months, on average, with my own gauge. Don't trust the inflator at the gas station or car wash, they are off. Spend less than $10 on a good gauge with a deflator valve. I overfill at the imprecise inflators and air down with a good gauge. I run 40 to 45 psi as long as it doesn't exceed the max psi on the tire. I use to run higher but its a pretty rough ride.
    Epiphany2000 likes this.
  14. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    42/40.........nitrogen or not.
  15. ETC(SS)
    7,497
    1. Go get yourself some black stem caps, and replace the lime green ones that are currently installed. They don't work any better than the green ones do, but it will keep the casual observer from thinking that you got scammed.
    2. Buy a decent tire gauge, if you don't already own one.
    3. Check your tire pressure regularly...like when you check your oil level, or whatever interval works for you.
    4. Repeat step #3.
    Enjoy your new car!
  16. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Well, only if the atmosphere on the outside the tire is oxygen free as well.
    So, pretty useful on those lunar shuttles.
  17. tlhamon
    tlhamon New Member
    30
    Flat Rock, MI
    As a chemist, I've heard all kinds of claims on this (go to a motorcycle forum and they will go into ridiculous details). All things considered, if you want to pay for it, fine, it won't hurt anything. The same can be said about the copper bracelets that golfer wear that supposedly harness their chi and make them sink putts. The absolute best thing you can do is put DRY air in your tires. Spend $20 on an attachment for your compressor and drain your compressor after you use it. AND, check your tires once a week. I do both and when I have had my tires changed after a few years, the interior was nice and pretty.
  18. RandomLurker
    RandomLurker Junior Member
    If you know of any unguarded bridges made of spider wire...
    And it's oil we motorcyclists go nuts over. Go to a forum now and ask what's the best oil. In two hours it will be littered with broken bottle glass and spent casings. :p
  19. tlhamon
    tlhamon New Member
    30
    Flat Rock, MI
    Oh I know, motorcyclists are obsessive about every minutiae. You can get some excellent advice on tweaking a machine to perfection.
    Doesn't change the science of reality though.
  20. ufourya
    ufourya We the People
    1,258
    336
    42
    I was browsing a lot in Austin, Tx., yesterday and found the dealer had, in addition to the B.S. multi-hundred dollar add-on for 'lusterizing' the paint, a $99 addition for nitrogen in the tires!
    Can you say, "No Thanks"?
